Author Topic: Beginners guide to buffing  (Read 6643 times)
iand123
Re: Beginners guide to buffing
« Reply #15 on: April 16, 2015, 01:49:25 PM »
Would they also be suitable for buffing oil/wax? That feels like a stupid question so sorry for asking if it is!
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #16 on: April 16, 2015, 02:23:44 PM »
The stitched mops would work, but loose is better, especially in a concaved profile as it moulds to the shape better
iand123
« Reply #17 on: April 16, 2015, 02:33:35 PM »
Ok thanks, i'll order these then. Best place for white compound (fancy trying both approaches)
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #18 on: April 16, 2015, 03:07:41 PM »
I'm still using the bar that came with my mops!  Maybe try ebay.  Search white or white diamond buffing compound
iand123
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #20 on: April 16, 2015, 03:42:04 PM »
should do the trick.
« Reply #21 on: April 16, 2015, 03:59:21 PM »
No stupid questions on here Ian  yes I have used them for both.
Alan.
« Reply #22 on: April 16, 2015, 05:43:13 PM »
I personally would use anything with any 'cut' in as they call it. If you do the sanding stage properly then it should polish up nicely.  Most polishing compounds with cut or abrasive in are designed for metals not woods like willow. You also want to look out for something that seals the wood rather than just makes it look pretty and shiny as it will soon start to absorb or loose moisture depending on where it is, particularly if you don't oil it as part of the process.
Speed wise slow is better. Mines around 1400rpm I think. As long as you don't put too much pressure and allow heat to build up you should be ok.
Tbh if the sanding is done properly you can get the wood to look great by hand polishing. Takes some time but can look good. Preparation is the key with most things
« Last Edit: April 16, 2015, 05:45:12 PM by Red Ink Cricket »
iand123
« Reply #23 on: April 16, 2015, 05:50:09 PM »
Thanks guys.
Just picked up the buffing wheels and put them into the drill. Getting quite a few cotton threads coming off. Is that normal? is it just a cheap wheel? Am I going too fast?
« Reply #24 on: April 16, 2015, 07:32:59 PM »
That's what should happen its trial and error at first but practice makes perfect what you can do though is reduce  the amount of pressure on the willow and if possible  use the drill at a slower speed also do as John (red ink ) as suggested and avoid polishing compounds as they will remove the oil or wax from your bat and as John as said moisture will then be lost rather than sealed into the willow.
