Scoring against good bowling
Author Topic: Scoring against good bowling  (Read 6537 times)
Re: Scoring against good bowling
« Reply #15 on: May 31, 2015, 12:07:13 PM »
Maybe I'm a dinosaur too but I think @richthekeeper's role in his team deserves a bit more respect. I think in most average levels of 50 over club cricket there is still a place for somebody to anchor the innings a bit and provide a platform the strokemakers and hitters. This isn't T20 we're talking about. When nobody agrees with that point or view I guess it's time for me to pack it all in  :(. So looking for methods to improve the effectiveness of somebody playing that kind of innings is a reasonable question.
Totally agree, but you must be able to rotate the strike and push singles if only to get the 'striker' on strike. I use a few methods:
1. vary where you stand. stand a good foot out of your crease for a few balls then stand back in tHe crease, you often then get a shorter ball as the bowler hasn't noted your change.
2. Identify places where you can push singles either by opening/closing the bat face, or playing slightly across the line
3. Come down the pitch, you won't be lbw usually and it negates the swing/seam
4. When batting and before you go in identify the weak fielders, left hangers etc and put pressure on the fielders by taking quick singles.
However, it is easier said than done. they are good bowlers because they are difficult to score against.
« Reply #16 on: May 31, 2015, 12:17:39 PM »
On drive
StonyFielder
    • Beyond Golf
« Reply #17 on: May 31, 2015, 12:21:35 PM »
Given the situation described -  I think the only issue is the scores made...
Going on at your comfortable scoring pace (or slightly faster as the ball is softer and the best bowlers tire) through to score 80, 90 or 100 not out is the important thing for you in my eyes.
You mentioned that the pitches and conditions haven't been entirely favorable and this makes manufacturing good balls into runs extremely difficult.
Every bowler is different but most are not content to bowl nonthreatening maidens the whole inning and this in itself will provide you with scoring opportunities.
That said - if you're up against a particularly patient bowler or a sunny day flat deck then it may be that you do look for more than survival and your go to shots. I personally favor third man as an area but it might be different for you - just two or three shots may be enough to persuade even the most patient and experienced of bowlers to come looking for your stumps, toes or chin and provide you with the scoring opportunity that you're looking for.
Hope that is of some help.
richthekeeper
« Reply #18 on: May 31, 2015, 12:42:01 PM »
Yep that's exactly it, I'd like to improve by adding that extra scoring shot basically so that I can disrupt bowlers without changing my game.
I think the main problem yesterday was I was facing left arm over with the keeper stood up. It's rare to face a left armer anyway and with the keeper up I didn't feel like i could come down the track.
We still won comfortably and our big hitting number 5 got 60* facing bowlers 4/5/6 so I feel like I did my job!
FirstSlip
« Reply #19 on: May 31, 2015, 01:20:28 PM »
Look to rotate strike as much as possible - agree with your opening partner on the way out that you are both going to be on the lookout for drop-and-run singles - bowlers hate this - but might be tricky if e.g. there is a short leg.
More specifically consider the field and the stock delivery - you talk about not risking third man because of the slip cordon which suggests at least two and a gully so there's a max six others.  Inswing: look at pushing to the gap between mid-on and mid-wicket - not too square at least early on.  Outswing: look at pushing to the gap between mid-off and extra.  Focus on placement rather than power.  What you're hoping to do is force a field change which will open a gap elsewhere e.g. slip comes out and you can then consider gliding to third man as less risky.  Obviously this applies to good bowling - anything pitching outside / missing leg stick is fair game and a half-volley is a half-volley - when these come along don't miss out by getting too excited and losing shape / trying to over-hit.
Hope that makes some sense?
addidasf55
« Reply #20 on: May 31, 2015, 02:39:51 PM »
Maybe you just had a problem with the angle?
At the end of the day if you have big hitters around you then you shouldn't change your game especially if it's a long game, every team needs that glue in the middle.
If you feel like you're getting bogged down against a bowler, then go discuss it with your partner?
And maybe mentally change the perception of what's a bad delivery ie everything outside off is not a good delivery and each ball should be played on it's merit. You can move forward as these guys said or even move back, anything to change the bowlers length. Anything to make more decent balls into bad balls.
When I go out and I bat number 3 usually I assess the conditions and for the first few overs I have 2 release shots in my head depending on the line and just try to rotate the strike initially. (Obviously if the bowler is pumped up and charging in, I'll charge him to put him back in his box haha). I also quite like little lofts over the top to push one or two fielders back so I have more access to singles.
But everything stated above is not to change your game but to have minor adjustments to allow you to play your natural game.
richthekeeper
« Reply #21 on: June 01, 2015, 09:31:19 AM »
these constructive replies are exactly what i was looking for :-)
a lot of what you guys have said, i already know and have done on various occasions - this has been helpful in reminding myself how to use those skills. as someone noted earlier, i don't struggle for runs, i'm just looking for ways to be better!
AdClem
« Reply #22 on: June 03, 2015, 08:36:17 AM »
I really think the "shine takers" are dinosaurs. Unless you are playing test match cricket, your goal should always be to put the bowlers under pressure.
Like you say bowlers probably love bowling to you as they get maidens. As a captain I might even want to keep you in for an extended period.
No need to go out and tee off but sometimes you may need to take a few risks. Fields up, balls hard, be positive mate.
I don't always agree with Michael Vaughan, but in a recent article in the Telegraph he said:  "...New Zealand have just realised the best way to get the most out of their players is to give them the freedom to play their natural game. If they try to sit in and play attritional cricket it hinders their players’ attacking instincts and will end in failure. They have realised their players are geared more towards the shorter format of the game. They are playing one-day cricket over five days....You need good pitches and the mindset of not being bothered about getting out, so you commit to the stroke. We have seen in Twenty20 cricket over the past few years that the guys who commit to the trick shots are successful and difficult to get out. We have seen from this New Zealand side in Test cricket that when they commit to the shot the ball travels."
This threw up some interesting comments: "After the first test when everyone was gushing about Cook's century, I made the point that the real story was in the batting strike rates, and that the Australians would likely be more impressed with Stoke's effort at a run a ball. Cook's batting is a holdout from a vanished game where the opening batsmen were there to take the shine off the new ball, wear out the bowlers and win some kind of antiquated war of attrition. The only certainty to be had by adopting that attitude in the 21st century is you will bore the fans to death.
Increasingly, Test sides (and the Kiwis were by no means the first, but good on them anyway) realise that you have to have a go from the first over. When it first started out, 50-over cricket was played like a shorter Test match, with batsmen playing themselves in, and not worrying too much about the run rate until about the 30th over or so. The realization that run rate was important from the start of play emerged in the 1980s. Then by the turn of the century, the relationship between the two forms of the game turned upside-down. I reckon Steve Waugh's Australian side were the first, but national sides started adopting one-day batting strategies to Test matches. Waugh's sides rarely scored less that 3.5 runs per over in domestic Tests, with 4 RPO becoming common.
Today it's progressed to the next level. One-day cricket is now being informed by T20, as we saw in the recent World Cup. England, playing the older form of ODI, never stood a chance, though on paper they should have made the quarters at least. Test cricket is evolving just as rapidly, and we now see the emergence of batting shots and bowling approaches developed mainly in the 20-over format. Michael Vaughan is correct in recognizing the trend in scoring rates; but its evolution began long ago, and not with New Zealand."
And: "The main thing T20 seems to have brought to Tests is that batsmen have realised that playing aggressively isn't as risky as was previously thought. You won't get out as soon as you have a go. There's even a hint of village cricket in there too - eventually you're going to get a ball you can do nothing about, so you have to put away every bad ball that comes your way before then."
Countered by:  "Cook can continue playing his game. Yes it's not riveting cricket, but it's effective.  Balance is always the key. If all your batsmen play like Cook, you will have a problem. If all your batsmen play like Stokes, you will have a problem too.  England currently have a pretty good balance in that regard, provided they continue to let the flair players play their game, even when it doesn't come off for a few games."
Cue jokes about Ballance.
Rob580
« Reply #23 on: June 03, 2015, 08:50:00 AM »
You need to have a get out shot, a shot where you can take a single that you can play in your sleep to a good length ball. Be that a run down to third man, a flick to midwicket or a punch through cover, you need to have a way to get up the other end. The guy can't bowl that well all day, either he'll tire and bowl you some bad balls, or he'll finish his allocation and you can take on whatever comes next.
Whatever the case, don't panic, you've got more time than you think.
Also, this talk of guys taking the shine off being 'dinosaurs', that may be the case in the professional game, but we're talking Saturday League amateur cricket here, i'd rather have someone bat the 50 overs for 80 odd and have plenty of guys around to boost that to a good score than have everyone swinging like madmen and go from scoring 320 to being all out for 80 the next week!
Akewstick
« Reply #24 on: June 03, 2015, 11:20:03 AM »
I can understand the sentiment of this, but you're imaginig the best way to get as big a score as possible on a good day. If the wickets start tumbling and you've got 11 thrashers in your side, that line up that can get you 300+ instead of 200 suddenly struggles to get into three figures. I can see the logic that you don't want too many slow scoring players, but there are so few of us around that one or two in a team is usually very handy.
In fact, at my level, even when we're having good days and the big hitters are firing, it's only have one or two barnacles in the line up that mean we bat the full 50 overs.
« Reply #25 on: June 03, 2015, 12:38:01 PM »
Along with seeing off the openers and new ball the  way you play is correct I play exactly the same but getting tied down does not concern me as I know that no bowler is good enough to continually bowl six unscorable balls every over and in any case as an opener you know your role in the team and there's usually others in the side waiting to bat who like to give the ball a wack after you have set the innings up for them to do so.
