Which lid?
Pages: 1 2 [3]
Author Topic: Which lid?  (Read 9191 times)
Re: Which lid?
« Reply #30 on: July 16, 2015, 08:49:04 AM »
Not sure I want to bat like Swann either!!
Going to need to sort the padding out inside it to make it more comfortable... still it could be worse.
Re: Which lid?
« Reply #31 on: July 17, 2015, 07:48:18 PM »
Further to this I wanted to mention that with the masuri grille it only weighs 100gramms more than the masuri shell with the same grille, which is pretty good.
Worth thinking about.
The ayrtek grille also fits, so with the adidas sale you can get a really good, bs compliant lid for around £60. Which I think is good value.
Re: Which lid?
« Reply #32 on: August 06, 2015, 03:16:15 PM »
Been having a conversation with GM about the lids and the possibility of a Titanium grille - they said that the new range will be out in September so it might be worth keeping an eye out then - also to remember
The Geo grille has been designed and positioned specifically for this helmet in the following ways:
- Possible impact points
- The gap between the peak and top wire of the grille is within a precise tolerance
- The position of the grille horizontally in relation to the front of the peak is within a specific tolerance
- The bottom bar of the grille is aligned accurately with chin clearance in mind
so if you have changed the grille - you have done it at your own risk and it is absolutely not recommended in any way by the manufacturer.
Pages: 1 2 [3]
