Pages: [1] 2 3
Author Topic: Frankenmallet, cheap and heavy  (Read 6820 times)
Jogetnz
« on: January 31, 2016, 08:53:25 AM »
Thought I would show you my GN mallet with additional weight added. May be an option for those not wanting to spend the big bucks getting a heavier mallet. Easily customised to the weight you need.
sarg
    • CricketBatInfo
Re: Frankenmallet, cheap and heavy
« Reply #1 on: January 31, 2016, 10:34:08 AM »
Keep that away from my bats. One miss swing and your in trouble lol
« Reply #2 on: January 31, 2016, 10:42:19 AM »
Exactly what I thought. One mis hit on the edge and you've got a shitload of scrap metal in the face of you brand new bat!!
A proper heavier mallet is cheaper than a new bat!!
#bodgejob
« Last Edit: January 31, 2016, 01:40:43 PM by smilley792 »
sarg
    • CricketBatInfo
« Reply #3 on: January 31, 2016, 10:59:42 AM »
Not exactly. My LV cost a bit....but loving it.
I reckon strips of the lead flashing used for roofing and gaffer tape is less lethal than that WMD. Top marks for originality... Far less for practicality.
« Reply #4 on: January 31, 2016, 08:58:06 PM »
Never ever am I using that on my bats lol. Kudos on figuring out a way to add weight but knowing how clumsy I am my bat would like a pot hole filled country road
dcullen8
« Reply #5 on: January 31, 2016, 09:15:28 PM »
Some serious plums required to be weilding that weapon!
Sent from my LG-D855 using Tapatalk
Jogetnz
« Reply #6 on: February 01, 2016, 05:26:57 AM »
Haven't had an issue using it yet, if I can't hit the bat with it from 12 inches away what chance have I hitting a swinging ball.
I'll take the feedback on board as it does look a bit nasty, cut off the rest of the bolt and it's a keeper.
« Reply #7 on: February 01, 2016, 05:39:55 AM »
That's a good idea. Maybe also straighten the weights to make it look less jagged.
sarg
    • CricketBatInfo
« Reply #8 on: February 01, 2016, 07:50:26 AM »
Expanding on your idea. How about using round washers and inset them on both sides about a cm with one of those hole cutter drill bits? Probably less weight but also no chance of edge death. You only need to get to 700 grams on that size mallet and the nut and bolt is part way there.
It only takes the mallet to skip off the edge and your in trouble. Leave it with you.
well past my peak
« Reply #9 on: February 01, 2016, 09:40:07 AM »
no, just no
ppccopener
« Reply #10 on: February 01, 2016, 10:33:39 AM »
can I please borrow this im going down to salix/newbery/m and h/GN to potentially buy a bat and I want to do my own ping test
do you think I would get thru the front door?
great thread
Jogetnz
« Reply #11 on: February 01, 2016, 05:23:45 PM »
great thread
Sure thing just come pick it up :)
Jenko
« Reply #12 on: February 02, 2016, 06:16:51 AM »
Forget the Mallet.
How good is the form of those socks!
Simmy
« Reply #13 on: February 02, 2016, 07:41:44 AM »
is this a joke?
Jogetnz
« Reply #14 on: February 02, 2016, 08:18:48 AM »
The socks are something else, Made by Stance, they are the best socks I've worn.
Simmy, the mallet is no joke. Today I cut the end off the bolt with some bolt cutters and the balance is a little better, also weighed it, 1.1kg and still struggles to make a mark on my new B3.
Pages: [1] 2 3
