Author Topic: AAAAAAAAARRRGGHHH!!! Batting, why is it so bloody complicated?!!!  (Read 3628 times)
Sorry, as this will probably be a stream of consciousness, but I wonder if anyone suffers the same frustrations.
So, club nets tonight - bowling went well, occasionally got biffed, occasionally troubled some first-teamers with my benders.
Then it came my turn to bat. For some reason the batting seems to have regressed, the main problem being my feet of stone. I can't seem to get across to off-stump, to play anything. I'm hanging back on leg-stump, and playing stuff from there, I really am struggling to get in line.
Last year, I took a couple in the face and neck, nothing serious only gentle glancing blows (I'm not a helmet wearer normally), but it seems to have made me afraid of the ball, and I hang back on leg-stump looking to free the arms.
Has anyone else suffered from this? I guess the key questions are is it a mental fix or a technique fix?
Should I just bat in a helmet, man up and get my head over the ball?
Should I exaggerate the back and across movement and plant myself on off-stump.
I have to say that at the moment, I am an adherent to the Buzz technique of leaning into the shot, rather than the trigger movement of back and across.
Re: AAAAAAAAARRRGGHHH!!! Batting, why is it so bloody complicated?!!!
« Reply #1 on: March 06, 2016, 10:30:07 PM »
Lid up if it's at the back of your mind mate, backing away to leg to try and play everything will seriously limit your range of shots.
« Reply #2 on: March 06, 2016, 10:35:33 PM »
Time to man up and where a lid.
Only valid reason I see not to wear one is if it effects your game, but it seems the fear of not wearing one is having a worse effect.
When I had a few facial injuries I too backed away and a helmet didn't help. I literally had someone fire tennis balls at the helmet till I stopped flinching to get over it.
« Reply #3 on: March 06, 2016, 10:51:30 PM »
Sounds like my night, last night. I broke the toe of my go-to net bat, took a good length sharp riser (uneven bounce) above my right ear, and pretty much hung back when batting. So, to your question:why?
Here are some reasons why I think I had a rotten net session last night:
1. This was my second net sessoin. I had had another one during the day at a facility that has fake grass like Astro - long fibers. A new ball was boucing like Perth. I hung back and played from back foot. I suspect that mind set seeped into my second practice where bounce was normal Astro bounce.
2. Dehydration. My legs wern't moving well and that normally happens when I am dehydrated.
3. No warm up prior to batting.
There was   something else as well: I was trying too hit hard. This is a mental block. I did recover from it but it took a lot of self-talk to just play the ball on merit. I sqaundered a good opportunity last night against very good bowling.
« Reply #4 on: March 06, 2016, 10:56:10 PM »
It's a confidence thing, and therefore mental issue!
A helmet will help as you will know that you are protected and that your Stephen Hawkin sized brain is safe!
Take your time and get used to wearing one and yes....try to work on getting your front foot over to the line of the ball and your head over the ball!
The rest should fall in place!
well past my peak
« Reply #5 on: March 06, 2016, 11:06:33 PM »
in my days of coaching juniors, seeing a young (and I guess older) lad cop one was always disheartening as you always new it was going to take a while for that confidence to come back.
In fact when you get anchored to the crease is when you are likely of getting hit.
My suggestion would be to focus on your head, get it in line and a lot of short fast soft ball work, it will take a little bit of time but it will come back.
« Reply #6 on: March 06, 2016, 11:11:16 PM »
Right, time to lid up and get used to it, it sounds like.
You can;t keep my kind of batting talent bottled up in a vessel of fear forever - it's time to unleash it on unsuspecting 3XI bowlers!
play-yourself-in
« Reply #7 on: March 06, 2016, 11:15:49 PM »
Often at the start of the season this happens to me and often it is because I'm thinking to much about it, relax and see what happens.  Another trick I try to get my feet moving is to pretend I'm playing drop and run so just imagine dropping the ball into the off side and setting off for a quick single, this keeps me on the balls of my feet and sometimes help.
Don't worry to much you'll be alright buddy.
Eliotroberts
« Reply #8 on: March 07, 2016, 06:37:16 AM »
I think wearing a lid will give you a bit of confidence mate,(ayrtek are the boys) also I no it seems a small thing but when you take a guard do you put your feet on the guard or bat? Reason I ask is my brother used to put his bat say on middle and his legs would be outside leg. I pointed it out to him and it seems to have helped. Could also be a mental block when you got hit was it coming across to play into the offside ?
« Reply #9 on: March 07, 2016, 09:42:42 AM »
Just think back to that mighty 50 you got last year, all chutzpah, power and virility.
 :o
Number4
« Reply #10 on: March 07, 2016, 10:10:45 AM »
It only hurts for a short time if you get hit Fattus.... Man up and get that front foot down the track ;)
« Reply #11 on: March 07, 2016, 10:35:32 AM »
It's ok, the retro 1990's Graham Gooch lid has just arrived, preparations are in progress!
hanif
« Reply #12 on: March 07, 2016, 10:55:15 AM »
@FattusCattus Opposition always love making comments about a nice bright shiny white helmet. I hope it fits nicely, enjoy.
hanif
« Reply #13 on: March 07, 2016, 10:56:19 AM »
On a positive note it is very light below 600 grams I think when I weighed it.
Batbuddy99
  • https://royalascotcc.co.uk
« Reply #14 on: March 07, 2016, 05:40:56 PM »
Last year in winter nets we had a session on short bowling and at the start to get rid of all the fear the coach made us pad up completely, the told us to try and duck/weave out the way or take the ball on when he stood 15 yards away and smashed tennis serves at our heads
That got us playing the short ball better and surprisingly made us less scared of being hit
Sent from my Nexus 7 using Tapatalk
