Author Topic: Kit and the extra ounce  (Read 6237 times)
Re: Kit and the extra ounce
« Reply #15 on: March 15, 2016, 01:16:28 PM »
What do you currently rock pad and glove wise @procricket B3 ?
[/quote
All in good time i'm working on stuff trying stuff out...
« Reply #16 on: March 15, 2016, 02:46:27 PM »
Us amateurs don't have any financial incentive to wear a heavier lid though remember! Or need to worry about 90+mph bowling, there's been more than a few internationals clearly changing because they consider the Masuri safer.
Percy
« Reply #17 on: March 15, 2016, 03:04:28 PM »
This really wasn't meant to be about masuri - I just used them  as an example. I maybe wrong but I thought I read somewhere that Masuri didn't sponsor anyone (wait for the deluge telling me how wrong I am :)).
Your absolutely right though, we very rarely have to worry about 90 mph bowling but we like the kit that can protect us against it so we buy it - its not really necessary but we like so we buy. In fact, we could probably get away with much cheaper lighter equipment giving less protection, which would be perfectly adequate for the levels I certainly play at,  but  it wouldn't give us the same pleasure  - thigh pads for instance.
« Reply #18 on: March 15, 2016, 03:15:33 PM »
Absolutely, my 1s skipper uses the youths Aero thigh pads which are much less protective for example, I was a bit dubious when he got them but he says they're much more comfortable for him and he clearly isn't bothered if he gets hit there, so fair play to him, makes sense and saves money. Gloves is probably the only thing where you want as good protection as possible I think, even though the bowling speeds are lower I'm sure we've all seen someone injure their fingers batting in amateur cricket.
« Reply #19 on: March 15, 2016, 03:28:41 PM »
I use a new style Masuri and only test match grade protection, speak for yourself not having to worry about 90pmh bowling!  ;)
Admittedly I've never cone across a bowler who can send it down at that speed, but ai like to know I'm safe if I ever do! If it's good enough for a Test Match, it is good enough to make me feel safe playing against the 13 year old, there to make up numbers and given a token 2 overs out of sympathy, in a Sunday friendly.
« Reply #20 on: March 15, 2016, 03:36:38 PM »
It is why i have always been fussy about pads and gloves...
I have been trying a new glove for the last month and got to say i could never use anything else due to it feeling like i'm batting with no gloves and not some kind of storm trooper fat padding.
Things that bother me are top hats that sit back and bulk around the sides and also gloves that have too thick a palm and you loose feel.
Feel of gloves is very important to me and it why i do not use inners but with pads i do not like pads that feel thick padded.
same here always have worn youth pads brought a pair of low grade GN gloves the other week to enable me to feel the bat handle as long as kit meets British standards it should offer reasonable protection.
« Reply #21 on: March 15, 2016, 03:48:47 PM »
I'm sure someone will correct me if I'm wrong, but don't believe there is a protection standard for pads and gloves?
TGB1997
« Reply #22 on: April 12, 2016, 10:36:27 AM »
I personally use a Masuri and have done for a while now. For a few seasons I had the older style Test Titanium and I currently use the Vision Elite Titanium. In the past I have used Gray Nicolls and G&M helmets and personally I felt they didn't fit my head particularly well especially the Gray Nicolls. Most players at my club are using Masuri helmets now or Albion helmets. Having faced some pretty quick bowling in recent years and have felt safer in my Masuri
Best Batting- 62
Best Bowling- 6/28
Best T20 Bowling- 4/3
« Reply #23 on: April 12, 2016, 11:33:56 AM »
Pads an gloves I'm fussier than my bats!
Once spent a full day in romida going through thousands of gloves
Then after finally going back to some top end slazenger ones , I had to pop back the day after to go through the pads!
Ended up with some cheapo gray nicks
All based purely on feel and comfort
HallamKeeper
« Reply #24 on: April 12, 2016, 01:52:57 PM »
I buy kit that is way too advanced for my level, pretty much the top of the range stuff that suits my game (low middle on the bat for our lifeless wicket). I buy only GN kit and Adidas for shoes and clothing as they do our team kit. I do this because luckily I have enough money and not many other expensive interests and also I hate not having matching kit. I don't like having dirty kit either. I know it is silly and won't make a difference to how my elbow stays high etc but if I think psychologically, if I feel I look good I get a little boost. I don't think someone with mis-matched kit is any worse, probably a decent player who doesn't need an ego boost through kit.
For keeping I get the top of the range gloves because I assume if they are for test players they have the best protection for my hands so minimise knocks that could stop me playing. Having said that I am currently rubbing ibuprofen gel into my finger in the hope it will be OK for the weekend after a nasty blow at nets. Maybe cheaper gloves would have resulted in a more serious injury, maybe not.
I didn't play senior cricket until I was 28 (4 years ago) so when I got back into it I had to buy everything. At that point I looked at all the gear and plumped for GN and have stuck with it ever since, so luckily I have only had to buy most things once.
TGB1997
« Reply #25 on: April 12, 2016, 02:11:53 PM »
I totally agree with you on the matching kit, I prefer to have my kit looking the same as it looks smarter. Feeling comfortable in and with your kit is psychologically very important as if you trust your kit then you are more likely to relax and be able to just play the game. There are plenty of other sports and famous sports stars that are like this.
Jenson Button (Formula 1)- is always trying to perfect the set up of his car to find the perfect balance
Phil Taylor (Darts)- Phil is always trying different materials and shapes for his darts as he's constantly looking for the perfect dart for his action
Neymar (Football)- he is one of the top Nike contracted players and is payed to market the Nike Hypervenom Phantom II, however he isn't comfortable in the Hypervenom Phantom II so recently he's been seen wearing the Nike Mercurial Superfly IV but the colour schemes on the upper have been made to look like the Hypervenom as he is contracted to advertise the Hypervenom range.
Being comfortable in your sports kit is in my opinion the most important thing
Best Batting- 62
Best Bowling- 6/28
