Pages: 1 2 [3]
Author Topic: New Helmet  (Read 8641 times)
Slyboogy
Re: New Helmet
« Reply #30 on: May 01, 2016, 01:51:02 PM »
New helmet has arrived, looking good,feels good when running, not used in the nets, just tested it by jogging in the house.
However I am having trouble adjusting the grille, I have been unscrewing it but it doesn't seem to budge?
Can you advise @Ayrtek?
Re: New Helmet
« Reply #31 on: May 01, 2016, 03:00:33 PM »
The nut caps will unscrew on it so you can adjust it, not all of the setting are viable as the grille was designed to fit other helmets as well using the different holes.
prav936
Re: New Helmet
« Reply #32 on: May 02, 2016, 08:08:19 AM »
Enter #freeshipping in the voucher code section the the checkout and it will knock off the standard shipping fee.
How much would you charge for shipping to Muscat, Oman?
Re: New Helmet
« Reply #33 on: May 02, 2016, 09:35:11 AM »
@prav936 drop me an email to tom@Ayrtek.com with your delivery address and I can get a quote for you via our Fedex account 👍
Slyboogy
Re: New Helmet
« Reply #34 on: May 02, 2016, 10:32:09 AM »
Yeah I have been doing that, but the grille doesn't seem to adjust/
Re: New Helmet
« Reply #35 on: May 02, 2016, 10:35:27 AM »
I'm not sure what you mean?
You can adjust the settings on it by swapping the position the rear holes are position by the bolt that's present? This will adjust the gap and distance the grille is from your face.
Jamesfield
Re: New Helmet
« Reply #36 on: May 02, 2016, 10:36:36 AM »
on the clearance helmets how do you adjust the size?
Re: New Helmet
« Reply #37 on: May 02, 2016, 10:40:44 AM »
@Jamesfield if you mean the interior size then the helmet comes with different thicknesses of foam padding that alter the size/fit.
Slyboogy
Re: New Helmet
« Reply #38 on: May 08, 2016, 11:53:59 AM »
@Ayrtek can you check your PMs please?
Pages: 1 2 [3]
