Pages: 1 [2] 3
Author Topic: Has anyone actually got a bowling machine in their garden?  (Read 18365 times)
Re: Has anyone actually got a bowling machine in their garden?
« Reply #15 on: May 18, 2016, 02:45:54 PM »
edit:
Construct the first home-fabricated bowling machine umbrella holder attachment, to stop the electrics getting wet, and you've got all weather at-home batting practice!
You mean an umbrella and duck tape?
Akewstick
« Reply #16 on: May 18, 2016, 03:06:44 PM »
Well, not as marketable as how I named it but I suppose so, yes.
bkenzie12
« Reply #17 on: June 07, 2016, 04:23:25 AM »
Hi there I have a small yard that's fairly open but I have an Ultra Sports Net with a pace,an original bowling machine. It's a fantastic setup and all easy to pack away!
The Palmist
  • Trade Count: (+15)
« Reply #18 on: June 07, 2016, 07:58:00 AM »
I have a long driveway with wall on both sides and garage at one end. Thinking  of getting a stinger  machine and just a pop up net for other side.
Not the same experience as bola but still good to practice  shots.
Biggie Smalls
« Reply #19 on: June 16, 2016, 01:43:41 AM »
I got a Stinger Pro . I live in a unit so have no backyard etc . Plus i dont drive . But the bowling machine , auto feeder , battery ,balls , etc all fit easily into my kit bag . I wheel my kit bag for a 15min walk down to the local nets . I get a few looks from people but i dont care . Its good practice and essential for someone like me who doesn't have much chance to do non club training with any pace bowlers or people who can use a sidearm properly .
Biggie Smalls
« Reply #20 on: June 16, 2016, 04:08:35 AM »
Reading these replies got me thinking . I had planned on buying a pop up net to place in front of the bowling machine . I think now i will buy chicken or baseball practice  netting . I can get some bungee cord and feed it through the top holes of the net and attach clips/ carabiners to the  ends of the cord . Then clip it to the side posts/wire netting of the  actual cricket nets . It would create something like a shower curtain effect . I could just move the curtain across when going in to collect balls . 5ft high x width of the nets seems good to me .
Harry L
  • Colts
« Reply #21 on: June 16, 2016, 07:17:40 AM »
Anyone got any pictures of their set-ups? Would be quite interesting to see.
iand123
« Reply #22 on: June 16, 2016, 07:39:18 AM »
Slightly off topic but which bowling machines are best (other than Bola which are a bit too much for me)?
Biggie Smalls
« Reply #23 on: June 16, 2016, 11:15:20 AM »
Um , depends .
Paceman original : uses light balls( or junior balls) , fires them at aprox 60mph . Not sure on weight , but I'm guessing pretty light (maybe 6-8kg ?)as its mostly plastic.From memory has a twelve ball auto feeder .
Paceman ltd : i think is pretty similar to original but can also fire ltd balls which fire a tad quicker than the light balls ( so maybe 65mph ?).I think these have a twenty four ball auto feeder . They look around a similar weight to the original .
Both these machines are capable of swing (i think) , but not sure about spin .
Paceman strike : heavier than above 2 as its metal , so sturdier as well . Doesn't do swing or spin as far as i know . Fires the light balls at 74.5mph . Also can fire reg /normal machine balls at 62mph . I think its auto feeder is sold separately and looks like its for twelve balls .
Paceman pro : as per strike model but can do swing and spin . Same speeds as strike too .
Ive seen theres a new 'kph'/velocity ball released recently by paceman which could be used on the strike and pro . Its a hard ball and apparently can be fired at 20% greater speed than a reg ball .
Im not sure how compact or easy any of the paceman models are re fitting in a kit bag etc . But they all look easy to pick up and move /pack into a car etc .
All the paceman models run on mains power . As far as i know there's still no power packs available . If you want to use them with a battery you need a car/12v battery and a pure sine wave inverter capable of 600w or better .
Theres also red coloured machines that look really similar to the original paceman . I think they are for American baseball market and are called Slider .
Swinger pro : a bit more compact than the ones mentioned above . Weighs 7kg . Only fires junior size balls that are slightly soft . Fires stinger balls and paceman junior balls at 80mph (but you cant use these balls with the 10 ball auto feeder) . It fires standard tennis balls at 80mph, heavy (cricket style) tennis balls at 65mph , and swing kings(half rubber half tennis ball) at around 70mph . Its ball feeder can come with a remote . It can do swing and spin .It runs off 12v battery .
 It does suck a bit that you cant use hard balls with this machine , but i got it because it fits in my kit bag , doesn't require mains power , and is capable of faster speeds (albeit with softer , junior sized balls) .
I guess for a home / backyard setup with available mains power , assuming bola/jugs machines are not a possibility,  I'd probably go for a paceman pro (especially if the kph balls do what is stated) .
If i was using the machine at outdoor nets via car transportation , id still probably go for the paceman pro . ( Getting a pure sinewave inverter is extra money that would be needed though ).
If someone is in my position ( no car , using it at outdoor nets ) id obviously suggest they get a stinger pro like I did .
Please feel free to correct me on any wrong guesstimates i may have made .
iand123
« Reply #24 on: June 16, 2016, 11:26:28 AM »
Thanks mate, really helpful. Are the paceman balls all hard/pimpled style?
Biggie Smalls
« Reply #25 on: June 16, 2016, 11:45:44 AM »
All the paceman balls are dimpled . The light balls and the ltd balls are hard but light (hollow ?) , the junior balls are dimpled ,  light and slightly squeezable. The reg(ulation) balls are stock standard machine balls ( like bola/jugs) . The new kph balls are hard, dimpled balls like the reg balls ... not sure what makes them higher velocity , but perhaps its some kind of enhanced dimple structure .
« Reply #26 on: June 16, 2016, 11:21:51 PM »
Am I the only one that finds the Paceman really unreaslistic? The ball floats out almost in an arc, and is nothing like what a real cricket ball does? its because of its one wheeled construction, well i presume it is, i havent tried the pro but Ive tried the standard paceman and thought it was a waste of money for any senior cricketer personally...
« Reply #27 on: June 16, 2016, 11:29:06 PM »
If you've only used the original machine the ball will float because it weighs 2 ounces. I agree it has limited use beyond helping young kids and beginners
« Reply #28 on: June 16, 2016, 11:40:49 PM »
@Vitas Cricket yeah agreed it was partially due to the balls but ive watched the paceman videos from dimension sport and the ball still seems to do the same thing, i suppose it isnt too bad for just grooving shots...
« Reply #29 on: June 16, 2016, 11:43:48 PM »
 I recently got Bola Junior and it is worth every penny!!!! For a club cricketer who can live with a max 65 mph speed, it is a great training tool.
Pages: 1 [2] 3
