Pages: 1 2 [3]
Author Topic: ICC - Restrictions on Bat Sizes...  (Read 6105 times)
Re: ICC - Restrictions on Bat Sizes...
« Reply #30 on: June 06, 2016, 01:08:02 AM »
I should add I did not invent this doubt! I am simply someone who has been convinced by reading and listening to intelligent discussion. And, for all the Sky hyperbole, I actually see more pros with what appear to be ordinarily sized bats.
« Reply #31 on: June 06, 2016, 06:27:54 AM »
I've two bats that I use regularly. One is a B3 low density cleft. The other a B3 butterfly willow cleft. They both weigh about the same, however, the Butterfly cleft makes a smaller bat as its density is higher than that of the Low Density bat. As an amateur, I hit straight sixes with both, about equally regularly, with similar amounts of effort. More importantly, in this experiment of n=1, I have gained muscle mass in the last two years and now hit the boundary far more regularly than I used to through getting fitter. The only time in the past I used to hit sixes fairly regularly was when I was using a 3lb+ bat.
What point does that prove? Only that the bigger volume bat isn't hitting the ball further, the bigger volume me is.
But lets look further at this, as streaky has done in the past: http://www.cricketbatblog.com/2015/10/14/the-cricketer-article/
Boundaries are definitely smaller and, perhaps most tellingly, pitches make all the difference. You only have to look at the county championship this season with the change in rules relating to who gets to bat first. Pitches are much more benign as a result.
You want to redress the balance between bat and ball? Don't look at the bat. Look at the pitch, the boundaries, the fielding restrictions and the ball. Address these, and if we are still seeing an outlandish number of runs, then maybe you can say "It's the bat".
well past my peak
« Reply #32 on: June 06, 2016, 07:43:30 AM »
yeah I think at the top end the wickets are far to batter friendly
sarg
    • CricketBatInfo
« Reply #33 on: June 06, 2016, 01:40:52 PM »
This simple experiment videoo may help illustrate the mass vs bat speed. Willow density is irrelevant. This has been discussed over and over, but sometimes seeing it helps.
https://youtu.be/0YVWJ9CqNJA
Pages: 1 2 [3]
