Pages: 1 [2] 3 4 5
Author Topic: Pressing!!!  (Read 10390 times)
GJ
Re: Pressing!!!
« Reply #15 on: January 08, 2010, 12:55:38 PM »
Great topic to start as i dont really have a clue as to what cleft requires what pressing etc, etc....
I would imagine the ideal pressing the average Joe Public would be between performance and longetivity.
Ive got a Salix and just seems to play better and better but the toe is absolutely awful. Ive got a feeling it will break around the toe area this year.  :(
Howzat
Re: Pressing!!!
« Reply #16 on: January 08, 2010, 01:42:27 PM »
Enough pressing to create a hard top layer but maintain a soft underlayer...
Worth an A- surely Norb?
SAF Bats
    • San Andreas Fault
Re: Pressing!!!
« Reply #17 on: January 08, 2010, 01:49:53 PM »
Leo you can have a B+ :-) an A answer would have been a bit more geeky quoting surface stiffness depths :-)  But that is the jist of it, for pressing very difficult to do mind you and therefore you have to knock in to finish it up
GJ strange on the Salix front for the toe is it a bowed blade?
« Last Edit: January 08, 2010, 02:09:03 PM by Norbair »
Email: cricket@safbats.co.uk
GJ
Re: Pressing!!!
« Reply #18 on: January 08, 2010, 01:58:35 PM »
Leo you can have a B+ :-) an A answer would have been a bit more geeky quote surface stiffness depths :-)  But that is the jist of it, for pressing very difficult to do mind you and therefore you have to knock in to finish it up
It is a bowed blade, and was extremely careful when i first used it. Always keep tape on it now when i use it as i think it would break otherwise...
But it is odd and cracks have started to appear on the bottom of the toe.
GJ
Re: Pressing!!!
« Reply #19 on: January 08, 2010, 05:04:40 PM »
Any particular reason this may be Norb?
SAF Bats
    • San Andreas Fault
Re: Pressing!!!
« Reply #20 on: January 08, 2010, 05:18:57 PM »
yes but I'd rather not answer that question!
GJ
Re: Pressing!!!
« Reply #21 on: January 08, 2010, 05:22:06 PM »
hmmmm yes, think i know too!
Was hoping it was some other reason though  :(
Talisman
  • Trade Count: (+76)
Re: Pressing!!!
« Reply #22 on: January 08, 2010, 05:24:30 PM »
Pressing....
The best would be to provide the minimal thickness of compressed face able to withstand the rigours of match play. Hence the theory that the 2 piece face only compresses on the thin strip.
Soft pressing does not equal more power, it reduces the power. If you ask your bat maker to soft press your bat and he says he has either he does not know enough or he is telling a white lie. There is an optimum pressing in each cleft, a peak on a power graph if you need to visualise it, the peak will move around for clefts and so the aim is to assess each cleft before pressing and hit that peak.
raymond
Re: Pressing!!!
« Reply #23 on: January 08, 2010, 08:28:02 PM »
Why do pros bats have such big profiles then, is that only due to density and not pressing?
SAF Bats
    • San Andreas Fault
Re: Pressing!!!
« Reply #24 on: January 08, 2010, 08:30:19 PM »
hmmm very good Talisman - would you say the power graph is a general exponential growth graph
represented by y =k exp(ax)(3)
Where y is the dependent variable, k is a multiplying constant so depth of stiffness, a is a positive constant so the willows elasticity and x is the independent variable pressure applied
SAF Bats
    • San Andreas Fault
Re: Pressing!!!
« Reply #25 on: January 08, 2010, 09:03:18 PM »
Quote
There are other bat makers and cricket bat researchers on here that could answer that question for you!
SillyShilly
Re: Pressing!!!
« Reply #26 on: January 08, 2010, 09:07:14 PM »
True, but there's only one Norb/Gollum (hows the cave working out for you)
SAF Bats
    • San Andreas Fault
Re: Pressing!!!
« Reply #27 on: January 08, 2010, 09:11:46 PM »
skulking is good.... pressing conversation is exciting... but need more opinions to get the discussion going, I might need to bait some people out. Afterall I'm supposed to be skulking not anyone else :-)
Fusion
Re: Pressing!!!
« Reply #28 on: January 08, 2010, 09:59:54 PM »
  Case Hardening ???
Fusion
Re: Pressing!!!
« Reply #29 on: January 08, 2010, 10:00:45 PM »
Compaction  ???
Pages: 1 [2] 3 4 5
