Author Topic: Thicker Handle  (Read 2167 times)
OllieWalker39
Thicker Handle
« on: August 03, 2016, 10:48:59 AM »
Short and sweet - I'm wanting to thicken up the handle at the bottom - have had bats with a nicer feeling handle before, so never felt the need! Best time to do it as I need a new grip anyway!
I'm wondering what tapes people use (i.e. elastoplast or something similar) - and how easy is it to get a grip back over the top of the tape?
Thanks!  :D
Jlscarroll17
Re: Thicker Handle
« Reply #1 on: August 03, 2016, 10:52:51 AM »
Use fabric strapping that's what I use and the grip goes on no problem
Re: Thicker Handle
« Reply #2 on: August 03, 2016, 10:56:33 AM »
Thanks!  :D
Don't use anything that's really thin and flimsy - you will end up having to use multiple layers of tape, and thin tape can tear when you're rolling down the grip.
I think anything other than thin scotch tape would be fine.
Nmcgee
Re: Thicker Handle
« Reply #3 on: August 03, 2016, 10:58:34 AM »
Any chance of getting someone to double bind the bottom half?
Back yourself.
Re: Thicker Handle
« Reply #4 on: August 03, 2016, 11:02:45 AM »
That's a good DIY projet. Pretty easy  (albeit slightly messy!) to do by hand.
OllieWalker39
Re: Thicker Handle
« Reply #5 on: August 03, 2016, 12:08:04 PM »
Was thinking of a double-binding, which could be possible! Although messy :D
I'll try some fabric strapping - kit bags full as I'm never in one piece!
330Mark
Re: Thicker Handle
« Reply #6 on: August 03, 2016, 01:02:25 PM »
I put a G&M shock absorber under my std grip on my Kudos2...thickened the bottom of the handle up nicely
Churchy1989
Re: Thicker Handle
« Reply #7 on: August 03, 2016, 10:08:23 PM »
Bought a bat off @19reading87 and rolled up the grip to find what I assume is a cut toe guard with tape on to make it feel like am oval shape. Good idea, maybe a few different items to use instead but a good idea to create what you want.
Have used hockey tape on one bat handle and just make the handle bigger where it suited me. Slightly expensive but was a good experiment and feels lush in the hands.....sweeky in the gloves.
ElPerro
Re: Thicker Handle
« Reply #8 on: August 03, 2016, 11:03:11 PM »
Have a you thought of trying half a grip under the main one? Easier to remove if you don't like it in the end
Re: Thicker Handle
« Reply #9 on: August 04, 2016, 12:44:00 PM »
You could cut up grips into 3inch inch long strips apply them till you get the thickest required.
Re: Thicker Handle
« Reply #10 on: August 04, 2016, 12:52:15 PM »
What @ElPerro and @Seniorplayer said...I fuss with my handles too and a thin (cheap  :D) second grip or half helps.
