Author Topic: This pink gear has gone far enough...  (Read 4463 times)
Re: This pink gear has gone far enough...
« Reply #15 on: January 15, 2010, 11:34:25 AM »
you need to spray it from an even distance over the helmet otherwise you will get blotches and patches where the paint runs, takes some practice to get it right. If your using normal spraypaint for cars etc do it in short sharp bursts rather than once continuous spray as this will lead to overload of the paint and drips forming again!
should be a distance of half a metre i would say should give you good coverage, try using an cross hatch format so you dont end up with an uneven coating.
