Author Topic: Handle String  (Read 8087 times)
Churchy1989
Re: Handle String
« Reply #15 on: September 21, 2016, 09:55:07 AM »
I would advise not doing it by hand, it really hurts. #HandCramp
Cow_corner
Re: Handle String
« Reply #16 on: September 21, 2016, 11:52:17 AM »
Thanks. Look forward to seeing them
Basically a couple of bookends (one with adjustment) some screws a couple of turned pins and a scrap piece of hardboard.
Cow_corner
Re: Handle String
« Reply #17 on: September 21, 2016, 01:54:46 PM »
Got some drawings or 3D Cad if you have a printer
Re: Handle String
« Reply #18 on: September 21, 2016, 02:29:25 PM »
Thanks for the photo I can make that what's the height of the pins from the  bottom of the hardboard
Biggie Smalls
Re: Handle String
« Reply #19 on: September 21, 2016, 02:48:23 PM »
Morning. Can you give us an idea of how much you need for each bat? What lengths do the rolls come in?
Thanks a lot. Justin
If you're asking re kinesio tape : about 2.5ft (rolls come in 5m lengths for $10-20, im using elastoplast brand , about $10au). If you're asking re medical tape : about 3ft (rolls come in 5-6m lengths for $5-8, ive always used the elastoplast brand rigid strapping tape ). Lengths ive mentoned are for taping the whole handle but ive experimented with 2 wraps on bottom and two wraps on the top and then the length is less than 1ft....this minimal method does work ok but leaves more flex in the handle . When using tape i still leave about 1inch of twine on the bottom of the handle to strengthen the shoulders . If i want the twine a bit lower than its done from the batmaker/factory , then i undo all the twine and rewrap , by hand, about 1inch worth where i want it , then wipe over pva glue to hold the twine .
Cow_corner
Re: Handle String
« Reply #20 on: September 21, 2016, 03:03:32 PM »
Half a bat (54mm) plus clearence, I'd say say 100mm, can supply drawings and stl files for 3D prints
