Author Topic: Refurb protip  (Read 3775 times)
Refurb protip
« on: October 13, 2016, 02:46:17 PM »
Don't use cheap scuff sheet! Decided it's time to give an old faithful some tlc as netting needs to be done and it's badly in need... As I recall I chucked a cheap scuff on in a rush to get this ready for a season start a few years ago. Regretting that now, enough of a pain getting it off before I've even started with the glue! Will post more photos when done, could be a bit of a long job though...
« Last Edit: October 13, 2016, 03:15:15 PM by edge »
Re: Refurb protip
« Reply #1 on: October 13, 2016, 03:26:18 PM »
Scuff and stickers finally off. Refurbers of CBF, what's the glue remover of choice? I've always got by with a sharp knife but going to be slow going in this case.
iand123
Re: Refurb protip
« Reply #2 on: October 13, 2016, 03:28:00 PM »
I find using white spirit and then a knife or old credit card works well
Re: Refurb protip
« Reply #3 on: October 13, 2016, 03:44:41 PM »
White spirit and a Stanley knife blade to scrape it off.
Ryan
  • Trade Count: (+17)
Re: Refurb protip
« Reply #4 on: October 13, 2016, 03:53:35 PM »
A draw knife at 90 degrees works well. Other long flat blades would work just as well. Also combine with white spirit.
tom line
Re: Refurb protip
« Reply #5 on: October 13, 2016, 05:33:25 PM »
I have a random orbit sander so just use some old sanding discs, doesn't matter what grit, as the glue just sticks to them to reveal the willow, then sand as you would with good sandpaper
GoodLeave
Re: Refurb protip
« Reply #6 on: October 13, 2016, 05:50:05 PM »
That looks ready for a refurb.
You thought about using the middle of the bat?  ;)
Agree with the above though, would go white spirit and a blade first up, finish by sanding any stubborn areas.
Re: Refurb protip
« Reply #7 on: October 13, 2016, 06:04:00 PM »
Ha, I'll try and claim the scuff has done its' job protecting the middle! ;) Was amazed how much outside edge damage there was when I took it off, normally I end up with cracks all over the inside edge and leave the outside pretty clean. It's severely dry so that clearly hasn't helped.
Cheers all, I'll get to work with the white spirit tomorrow.
Re: Refurb protip
« Reply #8 on: October 18, 2016, 08:12:24 AM »
Any progress on this one @edge?
Re: Refurb protip
« Reply #9 on: October 18, 2016, 08:32:10 AM »
Glue came off with the help of solvent, razor blade and patience:
Since then it's had a first sand and I've made good progress gluing and sealing up the outside edge cracks.
Still a little way to go yet, lots of glueing and sanding yet to do. Happy with progress so far though.
Re: Refurb protip
« Reply #10 on: October 18, 2016, 09:01:28 AM »
I'm a sad muppet... What razor blade did you use?  :D
Re: Refurb protip
« Reply #11 on: October 18, 2016, 09:14:06 AM »
Only you would ask! Was a Stanley blade holder really, similar to this: http://www.transtools.co.uk/ebay/ebay-STA028590.jpg
Bats_Galore
Re: Refurb protip
« Reply #12 on: October 18, 2016, 09:48:51 AM »
For sealing cracks do you use normal wood glue? Also does the fibre tape work as a clamp?
Re: Refurb protip
« Reply #13 on: October 18, 2016, 09:57:15 AM »
If it's just a thin surface crack I use superglue and sanding to seal it up, if something that needs lifting/glueing/clamping then normal wood glue. Haven't tried using fibre tape as a clamp, have always used an actual clamp or grip offcuts if it's a smaller break.
Re: Refurb protip
« Reply #14 on: October 18, 2016, 09:58:40 AM »
I don't know about fibreglass tape, but stretchy parcel tape is excellent for clamping repairs
