Pages: 1 2 [3] 4
Author Topic: Preparing a new bat  (Read 10666 times)
Re: Preparing a new bat
« Reply #30 on: January 04, 2017, 02:37:14 PM »
I hope the 3-5cm is a typo!!
What's a typo ?
ppccopener
« Reply #31 on: January 04, 2017, 03:01:27 PM »
typing error Senior
« Reply #32 on: January 04, 2017, 03:18:54 PM »
https://youtu.be/Hb90RsgbPI4
Pressing vs Knocking in. Short video by Whack Sports.
This is a bit of a confused video in my view.
Pressing and knocking in are both done to compress the bat face for optimum performance.
A shop roller can do the job of a mallet.
You need a hard/stiff bat face for performance.
« Reply #33 on: January 04, 2017, 03:29:58 PM »
GoodLeave
« Reply #34 on: January 04, 2017, 03:40:29 PM »
All bat reviews should come with a highlighter for a sense of scale.
Edges: 0.25 highlighters, etc.
« Reply #35 on: January 04, 2017, 04:28:29 PM »
Big Mac
« Reply #36 on: January 04, 2017, 04:46:44 PM »
The highlighter and ruler aren't aligned properly with the start of the scale drawn on the piece of paper. This is shameless Fox News style propaganda designed to embarrass Seniorplayer and I, for one, will not stand for it.
« Reply #37 on: January 04, 2017, 04:49:47 PM »
I can't tell if you took my post seriously, or you've just played a blinder... :-[
ppccopener
« Reply #38 on: January 04, 2017, 04:51:09 PM »
3cm-5cm mallet compression knocking in a new bat was so much more fun than 3-5mm
@Sitonit no more big edges on that bad boy  :)
radical.haqer@gmail.com
« Reply #39 on: January 05, 2017, 01:07:58 PM »
Is it a bad idea to take the knocked in bat in the nets against bowling machine with those soft dimpled balls?
jamesisapayne
« Reply #40 on: January 05, 2017, 01:15:58 PM »
I think it's a pretty good way of knocking a bat in, although some may disagree due to the quality of the balls.
There are some differences between the balls I think, have only seen red or yellow myself and they've been fine. As long as your bat has had a decent amount of mallet time and the edges and toe are well prepared an hour or two on the machine will help both the knocking in process and gets you a bit of practice too - what's not to like!
Just like having a net, you still need to be sensible though, i'd start off slow and build the speed up gradually until you're comfortable with it.
« Reply #41 on: January 05, 2017, 01:40:46 PM »
Buying (Pre & Post) a new bat isn't an easy task at all. Its almost like you've adopted a baby. So many things to take care of.
« Reply #42 on: January 05, 2017, 03:41:29 PM »
I treat my bats like a baby.
Big Mac
« Reply #43 on: January 05, 2017, 04:51:56 PM »
You shake it when it doesn't do exactly what you want, are forever comparing it to other people's bats and spend the rest of your life wondering whether those thirty seconds of excitement at the time of purchasing were worth it?
« Reply #44 on: January 05, 2017, 05:11:10 PM »
I'm not sure why, but the thought of your trying to compress it 3 to 5cm with a mallet has become a lot more worrying... :D ;)
Pages: 1 2 [3] 4
