Batting pad weights database
Pages: 1 2 [3] 4 5 6
Author Topic: Batting pad weights database  (Read 99888 times)
adb club cricketer
Re: Batting pad weights database
« Reply #30 on: February 07, 2017, 10:06:12 PM »
Mate - can I suggest you edit your original post each time a new pair is added, rather than having a shopping list every other post :)
That would leave only me to maintain this post, which is not in the spirit of this forum i guess ;) But yea, if the summary is cumbersome (which i understand), we ll leave users to just add their single entry and whoever needs the info will search through all posts
« Reply #31 on: February 07, 2017, 10:11:41 PM »
^ What happened to Aero pads that  I listed? :)
adb club cricketer
« Reply #32 on: February 07, 2017, 10:47:32 PM »
Can't expect the OP to do all the work
Thumbs up!
adb club cricketer
« Reply #33 on: February 07, 2017, 10:52:10 PM »
The weights difference between the left and right pads in the post were too off for me to trust the post, so left it behind  ;) If it is really correct, nothing stopping the author from inserting it in the "list"  :)
Calzehbhoy
« Reply #34 on: May 20, 2017, 08:56:16 PM »
Anybody got and know the weight of the new Predator 3 1500 pads at all?
« Reply #35 on: November 24, 2017, 03:42:32 PM »
Aldred - 959g each
BDM Admiral Super test pads: 740 grams each pad
Bradbury players: 837 grams
Charlie French PPR1 - 937g each
Gray  Nics Powerbow 750  each pad 567g
GN Prestige: 926gms per pad
GN Select pads: 950 grams
GN Supernova 900:  860gms.
GN Legend: 908 grams
GN Omega 1500: 883 grams
GM OLE pads 1040g each
GM OLE Sponsored player pads 944g each (old version)
H4l 50/50 are 800 grams per pad
H4L Custom 1029g
Helygen Momentum - 988g each
Kookaburra Ignite Pro pads - 878 grams
Kookaburra Rogue 650 pads: 818 each pad
Kookaburra Kahuna 550 - 850 grams
Kookaburra Kahuna Players (2015 model) - 793 grams
Kook Kahuna Sponsored player pads 989g each.
Kookaburra Onyx Pro - 737 grams
Kookaburra Onyx 700 - 907 grams
Morrants international 500g
M&H Distinction (old style) 929g
PRYZM Cricket pads : 760g
PUma Bionic 5000 780g
Puma evospeed 2, youth size: 640 grams
Puma Evospeed SL  mens pads - 690 grams
Puma Evopower SE Edition: 947 grams
Puma Iridium 6000 Felxtech pads with all velcro padding (high hat, knee roll and shin) included 766g each.
Puma Iridium 6000 Felxtech pads with knee roll padding remaining and high hat/shin padding removed 630g each.
Puma Platinum 6000 LE 860 grams
Reaper R1 - 974g each
Reaper R2 (not traditional looking though) - 656g each
Red Ink X1 - 869g each
SG RSD Prolite Youths pads: 680 grams each pad
SG Hilite pads: 828 grams each pad
SG Test batting Pads: 850 grams
SG VS 319 Ultimate batting pads: 793 grams
SG Litevate pads: 818 grams each pad
SS Test opener Mens size: 830 grams
SS Test Opener Youth size : 724 grams
Ten star pads: 780 grams each pad
Puma bionic and Morrants added
« Reply #36 on: November 24, 2017, 04:01:07 PM »
For a right handed batsmen, the right side pad is shorter than the left side pad, hence the weight difference.
I always weigh my gear at the post office scale and the numbers are correct. :)
PS: I have also CORRECTED the database to include Aero P1 size small pads.
« Last Edit: November 24, 2017, 04:13:00 PM by InternalTraining »
« Reply #37 on: November 24, 2017, 04:08:06 PM »
Aero P1 size small. Left pad - 481.94 grams (1lb 1.0 ounces). Right pad - 269.32 grams (0 lb 9.5 ounces)
Aldred - 959g each
H4L Custom 1029g
« Reply #38 on: November 24, 2017, 04:30:20 PM »
Aldred - 959g each
H4L Custom 1029g
Puma bionic 5000: 780g
Calzehbhoy
« Reply #39 on: November 25, 2017, 07:53:49 PM »
Aldred - 959g each
H4L Custom 1029g
RS Pro Edition - 874g each
« Reply #40 on: November 30, 2017, 07:12:03 AM »
Aldred - 959g each
H4L Custom 1029g
Puma Iridium 6000 Flextech pads with all velcro padding (high hat, knee roll and shin) included 766g each.
Puma Iridium 6000 Flextech pads with knee roll padding remaining and high hat/shin padding removed 630g each.
UZI Sports Test (Youth): 762 grams
Calzehbhoy
« Reply #41 on: December 30, 2017, 04:09:19 PM »
Has anybody got the SS Millennium Pro pads they could weigh for me at all please?
« Reply #42 on: December 30, 2017, 04:51:27 PM »
If you can get the search function to work I had I think the ss or Ton gladiators. Weight was very light, can’t recall if I weighed them tho but probably did!
« Reply #43 on: January 04, 2018, 05:00:07 PM »
GN Powerbow6 1500 weigh just 765grams each
joeljonno
« Reply #44 on: January 06, 2018, 11:12:40 PM »
Anyone know the weight of the MB Zulfi pads?
Twitter - @joeljonno
