Author Topic: Grading.  (Read 1390 times)
aman
Grading.
« on: January 22, 2017, 03:56:04 AM »
How does grading work nowa days?
What make "pro" grade willow what it is?
Is it purley asthetic? I haven't really seen any evidence that proves other wise but wanted to see if anyone knew anything else?
I've seen bats graded as grade 1 with lesser grains than a grade 2 or just as many from the same company, so how does it work?
sarg
    • CricketBatInfo
Re: Grading.
« Reply #1 on: January 22, 2017, 05:07:10 AM »
Bat grading is based on what the bat maker thinks a cleft will fetch.
Pro and player grades seem to be different depending on bat maker.
Willow grading is similar but generally defined as per J.S. Wrights grading.
http://www.cricketbatwillow.com/blades-grading
GoodLeave
Re: Grading.
« Reply #2 on: January 22, 2017, 08:25:37 AM »
I think the waters have been muddied somewhat recently by the invention of "Pro Performance" willow. Which seems to be any willow with a low density and/or better "Ping"
Density is a fact. "Ping" is subjective.
I'd prefer we just went to Pro (Lightweight), G1 (Perfect grain structure) G2 (Minor blemishes, graping, pin knots) G3 (substantial blemishes etc) Butterfly.
sarg
    • CricketBatInfo
Re: Grading.
« Reply #3 on: January 22, 2017, 09:16:59 AM »
The ICC limiting bat dimensions may make extreme low density clefts a little less important to some pros now the maximum volume of a bat may be 20+% less than the size of some the bats currently used.
A batsman who had a 2.10 50 mm edged bat with a 70 mm spine will still want a 2.10 bat. The B3 Beluga is a practical model of how that volume can be redistributed to achieve similar balance or playing properties.
Streaky what roughly is the volume of a unshaped short handled cleft of willow with a edge of 40 mm, spine 60 mm and a pressed camber of 7mm? That will be the max volume. Also what impact do you think the new restrictions have on grading in general?
« Last Edit: January 22, 2017, 09:29:03 AM by sarg »
Calzehbhoy
Re: Grading.
« Reply #4 on: January 22, 2017, 09:20:32 AM »
It's @The Doctor I think @sarg
sarg
    • CricketBatInfo
Re: Grading.
« Reply #5 on: January 22, 2017, 09:29:58 AM »
Re: Grading.
« Reply #6 on: January 22, 2017, 10:59:44 AM »
Natural low Density unblemished  light white  willow with tight  straight grains
