Author Topic: Oiling bat and Applying Anti-scuff  (Read 8473 times)
« on: January 23, 2010, 09:58:20 AM »
Dudes,
As the weather has finally decided to be dry and free of wind,rain,snow etc... I can finally sand my bat down outside!!
There are a couple of things I want to get peoples opinions on...
Firstly.... Do you think it is OK to apply a fine coat of oil onto the cricket bat, letting it dry , then applying an anti-scuff sheet? Or would this damage the bat in any way, and make the anti-scuff not stick?
Also I have seen a video where the bat maker applies the anti-scuff sheet to the bat, and then only oils the back of the bat. Would this not effect the willow on the face having not had any oil on it....
Which do you guys think is better?
And another thing.... When applying my anti-scuff what do you think is the best way to apply it to the 'toe' of the bat and could somebody pot a pic of the anti-scuff at the toe of their bat so I can get a rough idea.
I PROMISE THIS WILL BE MY LAST TIME OF GETTING PEOPLES THOUGHTS!! I JUST NEED TO KNOW I'LL BE DOING THE CORRECT THING.... :)
Reds
« Last Edit: January 23, 2010, 10:08:14 AM by 19reading87 »
Aswani Cricket
    • ASWANI Sports
Re: Oiling bat and Applying Anti-scuff
« Reply #1 on: January 23, 2010, 01:40:53 PM »
If you're sanding the bat down, then yes, apply a thin coat of oil, wait till it's completely soaked through (a couple of days), wipe it down with an old cotton t-shirt, then apply the anti-scuff.  Don't buy cheap anti-scuff as it may not stick.
I wouldn't apply anti-scuff to the toe, it will just come off. Apply some oil.
ASWANI Sports
http://www.aswanisports.com
Washington
« Reply #2 on: January 23, 2010, 01:45:52 PM »
Im guessing if you put oil on it first the anti scuff sheet wont stick properly until the oil has completely dried which may take a few days/weeks.
I dont think not oiling the front is a problem unless you DONT fit a anti scuff sheet. Oiling the back will be sufficient to keep the blade from drying out.
Finally leave a few millimeter gap at the bottom so that the anti scuff she doesn't peel up when tapping the bat on the wicket/mat/boot.
Formerly CustomDan21
« Reply #3 on: January 23, 2010, 04:59:57 PM »
Cheers guys :)
Do Aswani cricket stock decent anti-scuffs???
« Reply #4 on: January 24, 2010, 04:43:31 PM »
Any more info guys?????
GJ
« Reply #5 on: January 24, 2010, 04:46:46 PM »
Just watch this video and it tells you everything you need to know about preparation...
You can oil the face before applying the facing, but it doesnt matter if you dont.
« Reply #6 on: January 24, 2010, 05:03:51 PM »
Cheers for the link GJ :) I have applied a very thin layer to the face, I will allow this to dry completely before fitting the scuff sheet.
Ashvir
« Reply #7 on: January 24, 2010, 05:56:58 PM »
I oiled my bat and applied a scuff sheet and it didnt stick
niceonechoppy
« Reply #8 on: January 24, 2010, 06:02:36 PM »
How long after oiling your bat did you stick the anti scuff on? Which anti scuff as well?
Ashvir
« Reply #9 on: January 24, 2010, 06:28:20 PM »
7 days after. I applied a Hammer Edge
niceonechoppy
« Reply #10 on: January 24, 2010, 06:32:27 PM »
Seems strange, every time i apply a anti scuff i leave about 1-2 after its oiled and ive never had a problem.
Ashvir
« Reply #11 on: January 24, 2010, 06:37:38 PM »
I think I over oiled the bat
niceonechoppy
« Reply #12 on: January 24, 2010, 06:41:02 PM »
Yes must be that, because the moisture in the oil hasnt dried in the bat.
