Pages: 1 [2] 3
Author Topic: Left Handed Bowlers - what do right handed-batsmen prefer?  (Read 7041 times)
Re: Left Handed Bowlers - what do right handed-batsmen prefer?
« Reply #15 on: February 20, 2017, 03:29:34 PM »
As a left hand batter love left arm around bowlers  have them for breakfast
Really?  I thought you just had your vitamins!
six and out
    • MKCC website
« Reply #16 on: February 20, 2017, 03:38:54 PM »
i think at the end of the day it is best to be able to have both up your sleeve as they are often useful in different circumstances.
For example our 1st XI opening bowler is a left armer and he always starts coming over swinging it in with variation of straight on'a for the slips there for a nick etc....
However he often comes back late in the game when the ball is knackered and not swinging and then he goes round the wicket bowling yorkers, slower balls, cutters etc... which are more effective over the wicket
« Reply #17 on: February 20, 2017, 03:53:38 PM »
Vitamins first bowlers second
« Reply #18 on: February 20, 2017, 04:04:10 PM »
I'm a Sugar-Puffs kind of guy!
« Reply #19 on: February 20, 2017, 04:05:08 PM »
I love left arm over. Open up my stance and try to cover drive everything through mid off
Left arm round annoys me, cramps me up, although it's usually off Pad on to wicket as opposed to anything lbw I got out to.
« Last Edit: February 20, 2017, 04:13:51 PM by smilley792 »
« Reply #20 on: February 20, 2017, 04:09:12 PM »
I find if I am getting cramp for room a change of guard helps
« Reply #21 on: February 20, 2017, 04:30:20 PM »
You can make life a lot more difficult for most batsmen bowling over and mixing inswingers with ones that keep going straight across, so I'd always start that way and move to bowl around if you think you're better off there for a particular player.
« Reply #22 on: February 20, 2017, 04:43:40 PM »
I think
Most left handers cope well with the ball going across them why because they are used to it
« Reply #23 on: February 20, 2017, 05:22:14 PM »
No good asking me, as your bowling ties me up in all sorts of knots.:-)
Most batters are not expecting that late In Swing from a left hander
Left arm over all day, work on your line and length, then work on a slow ball.
Short run up, and bowl all day.
Bowling prize every season sorted
« Reply #24 on: February 20, 2017, 06:02:05 PM »
Right - so the general consensus seems to be have a crack at left arm over then as more RH batsmen find it trickier.
Manormanic
« Reply #25 on: February 20, 2017, 06:12:07 PM »
Over the wicket with the occasional handful of balls from round as variation.
Over the wickte, you keep both edge of the bat in play, which means you have a decent chance of getting wickets bowled, caught in the cordon, LBW.  Round the wicket, you are really bowling to hit the stumps only.
Also, think about scoreboard pressure.  If you are reliable with your line, you only need fielders through about 220 degrees over the wicket at no great pace - this means you can pack the field in key areas.  Round the wicket, you need to cover more like 280 degrees.
JB
« Reply #26 on: February 20, 2017, 06:49:07 PM »
Very rare if ever that I would bowl around the wicket. You just get clipped through the legside too easily
felix
« Reply #27 on: February 20, 2017, 09:18:14 PM »
I'm with the majority Bruce, I find you hard enough to play at the best of times but always thought you should bowl over, you could get lbws for fun! Coming round, the angle is always be a bit against you. But being able to come round as a variation, especially if it's swinging less, will always be useful.
Calzehbhoy
« Reply #28 on: February 20, 2017, 09:29:45 PM »
If you can swing the ball back into a RH as a left hand over with a bit of pace you'll never be too far from the bowling trophy at the end of the year.
Woodyspin
« Reply #29 on: February 20, 2017, 09:36:21 PM »
generally talking, Left arm over to start to the right hander, especially early on. They will have a tendency to feel outside off for the ones that go straight on, and they will fall over or be trapped on the crease plumb in front. Having said that, if you find that a player is strong through the covers, your option is to swing it in to the pads to tight them up.
Me personally, batting wise, i like your round the wicket, i havn't struggled much with that as of yet. And i've been known in the past to dispatch left arm overs all through the leg side, especially v Eastbourne.. it was their captain, we were 103 for 8... he didnt like me driving him past mid on on more than on occasion!
Pages: 1 [2] 3
