Minor toe cracks..Suggestions please
Pages: 1 [2] 3
Author Topic: Minor toe cracks..Suggestions please  (Read 8914 times)
prim0pyr0
Re: Minor toe cracks..Suggestions please
« Reply #15 on: June 05, 2017, 06:03:58 AM »
what type of glue did you use?
Churchy1989
« Reply #16 on: June 05, 2017, 01:29:05 PM »
I would not be surprised if that opens up again, it doesn't look like you got a tight enough binding/clamping.
Good first try though.
LBWCandidate
« Reply #17 on: June 05, 2017, 01:52:12 PM »
Gorilla Wood Glue.
LBWCandidate
« Reply #18 on: June 05, 2017, 01:54:52 PM »
Thanks. I did wrap up with plastic like Julians video shows and then clamped it tight for more than 24 hrs. Still, it doesn't look that tight.
Maybe needs longer/tighter clamping and then fiberglass tape.
Churchy1989
« Reply #19 on: June 05, 2017, 01:59:54 PM »
The Toe is quite hard to do, you need some off cuts of wood and place on the back, so when its clamped its like a square block and not at an angle on the back (due to the shape of the toe, its never square or rectangle). Hope that makes sense.
I use wooden doorstops and bits of wood.
« Reply #20 on: June 05, 2017, 03:03:01 PM »
I wouldn't recommend gorilla glue. It requires the surfaces to be damp to cure, it expands as it cures (this may explain the issues you had clamping it) and it sets too hard and may cause further cracking.
tom line
« Reply #21 on: June 05, 2017, 03:11:15 PM »
That's only the normal gorilla glue that does that, the wood glue they do acts in the same way as any other wood glue in the application and setting properties, and is excellent too
« Reply #22 on: June 05, 2017, 03:28:15 PM »
cheers. Didn't know that. I have always used PVA.
« Reply #23 on: June 05, 2017, 03:38:40 PM »
Thats whats gorrilla wood glue is, except it costs more than unbranded PVA.
tom line
« Reply #24 on: June 05, 2017, 03:43:07 PM »
PVA generally refers to white wood glue, where as gorilla wood glue uses natural wood resins leading to it drying a yellow/orange colour the same as titebond wood glued, I think they may be called PCA instead of PVA because of this if I remember correctly, both work exactly the same really, apart from gorilla glue I've found dries a little better in deep cracks where as PVA can sometimes take a few days to dry if its deep in the bat like for serious delamination
« Reply #25 on: June 05, 2017, 03:53:09 PM »
My experience is just the colour difference, but open to being told otherwise, its still bloody expensive by comparison though lol.
« Reply #26 on: June 05, 2017, 04:00:06 PM »
Polyeurathane glues expand as they cure and require moisture to cure. PVA glues do not expand and cure by evaporation. I believe they have similar strength properties though. I guess it depends what you personally prefer.
tom line
« Reply #27 on: June 05, 2017, 04:04:36 PM »
Yeah it is,
Think gorilla was little 200ml for £5 and I got my big bottle of 5 litres for £15 😂
LBWCandidate
« Reply #28 on: June 05, 2017, 04:13:25 PM »
Based on reviews online and other places, I picked Gorilla wood glue.
« Reply #29 on: June 05, 2017, 04:18:29 PM »
Gorilla wood glue is just PVA, not sure if it has any benefits over cheap brand PVA's or if you just pay for the name.
Pages: 1 [2] 3
