Author Topic: Lighter bat..technique back in sync...all in the mind, or not?  (Read 4327 times)
Re: Lighter bat..technique back in sync...all in the mind, or not?
« Reply #15 on: July 04, 2017, 08:24:11 AM »
He'd only scored 277 against Australia at the SCG before that point, totally hopeless...
Battings a bit different in the UK.
pablomarmite
« Reply #16 on: July 04, 2017, 08:55:30 AM »
I've used all different weights over the years but predominantly very light e.g. 2lb 5oz harrows. This season I scored a ton in first game using a 2lb 11.6. However not only was the bat weight vastly different but so was my technique. The handle then broke and this put the weight up again. I've actually added a second grip so we are looking at 2lb 14 or there abouts now. I usually open but dropped down to 5 on Sat and was involved in a run chase with spinners at each end, no cuts or pulls. Will be much more interesting when I use it to open against the new ball. I find more important than weight or pick up is feel in the hand. Rather than hundreds of bats I seem to have hundreds of grips. So for me handle size, shape and grip seem to play a big part in my mind.
The game I had to use my lighter bat while my new one was broke I scored 1. That was prob more down to a good bowler bowling a good ball as opposed to the bat though.
However finally there is no doubt that the difference in weight between say 2lb 5 oz and 2 lb 14 oz is noticeable and your technique and range of shorts will be different. In my opinion I can't see 2ozs up or down is one noticeable or two going to affect your batting in any way except possibly in your head!
dannyhall04
« Reply #17 on: July 04, 2017, 09:18:02 AM »
In a UK county game? Incredible!
« Reply #18 on: July 05, 2017, 08:53:28 AM »
And 375 against England the winter before he came to Warwickshire.
tomorpe
« Reply #19 on: July 07, 2017, 11:17:35 PM »
Well I confess, I'm not a bat-blamer....you know, a few low scores and bin the grade 1 for another grade 1 on the basis it's not getting any runs...but I do 'fiddle around with things a bit here and there'
Your either reading this thinking...ah...I know what he means...or...you just pick up any old weight and do well. I guess there always will be two camps  :)
Anyway not been a great first half of the season so picked up a cheapest lighter bat, about 2-3 oz's lighter than last weeks one and guess what? Stance seems better, more upright, the bat feels better being lighter, and I've started to time a few out of the middle. I generally face a newish ball and a slightly higher middle appears to be working.
So first half of the season I pushed it to use as heavy as I could, second half the complete opposite...
But is it all in the mind I wonder because I can use something heavier and still play with it?
Apologies if this same subject has been posted before and boredom has already kicked in  :)
I never get bored of talking bats and technique...and most important - how to get as many runs as you can
I feel the same. I struggle to find rhythm with a heavier bat when I am out of form. I also struggle to play the pull shot with a heavier bat but if I use a teammate's heavier bat in practice, it makes it a lot easier for me in game with my 2lb, 9oz bat. I play and live in cornwall, where the wickets are very slow and low which would make it difficult to be a back foot player and use a bat with a high middle. Having a bat with a low middle makes the pick-up feel not as nice and makes the bat feel a lot heavier. It does, however, make drives luxurious and give more power of the front foot. I completely understand your situation.
