Custom Bat from Robinson Sports
Author Topic: Custom Bat from Robinson Sports  (Read 6908 times)
KW9221
Re: Custom Bat from Robinson Sports
« Reply #15 on: September 30, 2017, 03:53:59 PM »
@InternalTraining ping is fantastic. It pings all over the blade.
@kal_m wow what a profile. What are your specs?
@BatGoonMcClintock thanks pal for uploading the pictures.
« Last Edit: September 30, 2017, 04:06:52 PM by KW9221 »
Instagram: Cricketer_guru
BatGoonMcClintock
« Reply #16 on: September 30, 2017, 03:56:06 PM »
@kal_m what is the weight mate?  What are the spine, toe, edge and shoulder measurements?  Are you going to scuff it?  Also, what is the length of the sweet spot?  What's the response up high for pulls and cuts, seems like there is a lot of meat up high near the stickers for a low middle bat.
« Last Edit: September 30, 2017, 03:57:50 PM by BatGoonMcClintock »
kal_m
« Reply #17 on: September 30, 2017, 04:30:52 PM »
2.13/40 mm/24 mm toe/17 mm shoulder/67 mm spine. I mentioned to Mr.Surinder that I prefer performance over looks. Looks like he hit both marks (IMO atleast)
@BatGoonMcClintock, not a big fan of scuff sheets but I will tape the edges. The response is pretty good 2 inches from the bottom all the way to the stickers. Definitely one of the best I have seen.
Aspire and Achieve
KW9221
« Reply #18 on: September 30, 2017, 05:10:37 PM »
Wow big bat! Mine is only 2.10 with 46mm edges and 74-75 mm spine height and 26 mm toe.
e4sby
« Reply #19 on: September 30, 2017, 06:10:35 PM »
What’s the cost delivered to U.K. for a custom G2 Robinson?
Andythomo21
« Reply #20 on: September 30, 2017, 06:56:13 PM »
Won't deliver to the UK mate as The Cricket Shed is their authorised dealer in the UK I believe.  Will only deal to individuals outside the UK, of UK customers who are starting a brand etc.
kal_m
« Reply #21 on: September 30, 2017, 07:20:31 PM »
Wowww....that's massive.Did you get a special cleft or something??
Aspire and Achieve
manno
« Reply #22 on: September 30, 2017, 07:23:46 PM »
A heap more concaving on his would explain those specs.
KW9221
« Reply #23 on: September 30, 2017, 07:33:47 PM »
@manno exactly. I wanted light pick up. I wanted a hybrid version of Kaboom but with my personal touch.
@kal_m yes it was a special cleft. It took him almost 3 weeks to source it.
