GN Kronus Halesorm v GN Pro Performance, which is better?
Pages: 1 [2] 3
Author Topic: GN Kronus Halesorm v GN Pro Performance, which is better?  (Read 13973 times)
Umi
Re: GN Kronus Halesorm v GN Pro Performance, which is better?
« Reply #15 on: February 01, 2018, 03:02:21 PM »
I would recommend getting Aussie Gray Nicolas bat
« Reply #16 on: February 01, 2018, 03:40:34 PM »
@Seniorplayer do you mind sharing where you sourced your 2 in 2lb6 from?
From memory Vitas and Uzi had a couple of "light" ones in 2lb9/2lb10 but they were like rocking horse poo. Getting 2 in an even lighter weight is unreal luck :)
Calzehbhoy
« Reply #17 on: February 01, 2018, 04:11:30 PM »
I have a Halestorm (Predator, not Kronus) that is 2lb 9.5 and is bloody lovely! Pick up and performance are top notch and would recommend.
liscon12
« Reply #18 on: February 04, 2018, 12:27:36 PM »
The xxx11 range from meulemans are stunning got three on order for guys on this forum I think @Northern monkey @petehosk will agree stunning bats and would have change as well from what a uk hailstorm would cost you that’s with custom charges as well
Do you buy direct from Meulemans or get someone over in Aus to buy for you then they ship?
I'm just worried about it getting dinged up while being shipped here .
simonmay5
« Reply #19 on: February 04, 2018, 03:29:36 PM »
Nope just had a quick search if anyone wants a light one They are on barring ton sports website
@Seniorplayer would love to see the 2.6 pro Performance must be a very special cleft to get one in that weight
simonmay5
« Reply #20 on: February 04, 2018, 03:32:45 PM »
Yes direct if I had known you wanted one could of added to the order I have put in for three xxx11 for members of this forum all going in the same box and they said they will put the value of just one bat so hopefully we don’t get stung for three bats they are extremely good value for money as well and all guaranteed to be made by Stuart Kranzbuhler
liscon12
« Reply #21 on: February 04, 2018, 04:04:40 PM »
Only seem to have the custom model left, is that what you guys have bought?
simonmay5
« Reply #22 on: February 04, 2018, 04:16:25 PM »
A mixture of limited edition and players grade bats not a lot of difference between the grades to be honest with you all seem to ping well and be massive for the weight always worth sending them a message as always really helpful
Chalkie
« Reply #23 on: February 11, 2018, 01:03:48 PM »
A couple of people have mentioned about the shorter blade on the GN PP and that not being tall themselves means it shouldn’t be a problem. Does this mean that if you are taller (I’m 6’2) the PP would be harder to get on with?
Any taller guys on here got a shorter blade, longer handle set up they use regularly and can comment on this?
« Reply #24 on: February 11, 2018, 10:01:31 PM »
I use a Kudos or Warbird from time to time and actually seem to get on as well (sometimes better) than SH or slightly longer blade!!
Chalkie
« Reply #25 on: February 11, 2018, 11:16:17 PM »
Cheers mate, I forgot the warbird was that style. Used Bruce’s one a while back and it was great so think I will try this set up again.
« Reply #26 on: February 11, 2018, 11:45:40 PM »
Next net let me know if you need me to bring one with me?
« Reply #27 on: February 12, 2018, 10:42:46 AM »
Warbirds are great, you really don't notice the difference and get a bit more wood for your buck.
« Reply #28 on: February 12, 2018, 03:38:01 PM »
I've got a couple, never had any problems using them although it does change the balance so can see why some don't like it. However, isn't the problem with the Pro Performance is that it's not your usual sb/lh setup but that the whole bat is actually shorter than standard? Worth checking to make sure.
Chalkie
« Reply #29 on: February 12, 2018, 04:11:55 PM »
Is it really a smaller bat? All the adverts (and the GN catalogue) talk about a 1 inch shorter blade, but they say it is a SH bat so assumed the handle was longer to make up for the blade?
Surely if the whole bat was 1 inch shorter they couldn't call it SH?
@Seniorplayer can you confirm if it is indeed shorter than the usual SH?
Pages: 1 [2] 3
