GM QDK Players Edition
Author Topic: GM QDK Players Edition  (Read 24705 times)
Re: GM QDK Players Edition
« Reply #15 on: July 20, 2018, 05:10:56 PM »
Gm make all bat shapes to 2-10 finished weight. Density then plays it part in the finished weight. The Ben Stokes bat I had in weighed 2-8 1/2 and was rediculous size for the weight.
GM have made the haze max to get bigger bats for a lower weight. Some won’t go thru the ‘guage’ And have been 2-12
Ajdal
« Reply #16 on: July 20, 2018, 05:19:18 PM »
If you get a haze max under the 2.11 mark let me know
« Reply #17 on: July 20, 2018, 05:37:50 PM »
So, they will make oversized bats for clubbie customers?
« Reply #18 on: July 20, 2018, 06:42:05 PM »
Well sort of, they are no where near as big as the select extremes but are big for GM
« Reply #19 on: July 20, 2018, 07:13:54 PM »
What are "select extremes"?
« Reply #20 on: July 20, 2018, 09:29:01 PM »
Same as the one for sale in the for sale section
« Reply #21 on: July 20, 2018, 09:41:01 PM »
Didn't find anything...not sure what you are talking about. Never mind.
stevat
« Reply #22 on: July 20, 2018, 09:45:51 PM »
He means the sale section of this site, not his own:
http://custombats.co.uk/cbforum/index.php?topic=44764.0
« Reply #23 on: July 20, 2018, 09:51:58 PM »
^ Thanks!
adb club cricketer
« Reply #24 on: July 20, 2018, 10:11:52 PM »
Referring to Gray Nicolls Select Extreme bat
Mfarank
« Reply #25 on: July 20, 2018, 10:46:59 PM »
Not to be overly critical but this looks too concaved for a 2-10 bat for my liking. Its rare to see pros use such concaved shapes usually their bats are quite full almost dome shaped. Makes me question whether it really is the exact profile and weight QDK uses. Grains look lovely though and im sure it pings like a cannon
« Reply #26 on: July 21, 2018, 02:45:44 AM »
^ I have concaved bats and have unreal ping! I wouldn't worry about it. As long as the concaving does not go below the edge level, there is no degradation of performance per James Laver.
The man whose bats I want to steal uses concaved bats: https://www.youtube.com/watch?v=E_g3w9q4Cj8
alexevo94
« Reply #27 on: July 21, 2018, 04:29:16 PM »
i'm pretty sure Joe Root's bat is concaved as well
« Reply #28 on: July 21, 2018, 04:37:06 PM »
What is the reasoning behind performance being effected as soon as the concaving sips below the edge?
adb club cricketer
« Reply #29 on: July 22, 2018, 04:42:29 AM »
I think when concaving dips below edge level, you are basically putting more wood at edge than between edge and middle (where it dipped below edge level), which doesn't make any sense as you either hit the ball off the middle or between edge and middle i.e. off centre. As long as concaving is above edge level, compared to convex shape with small edge (comparing at same weight/volume of wood available to work with), you are basically spreading out wood all along the way towards the edge resulting in a wider sweet spot compared to no concaving/convex back but with small edges.
From personal experience, i did find slightly concaved bats/modern bat shapes had wider middles compared to convex bats with small edges/old bat shapes. Not to mention, pickup is almost always better with concaving, maybe something to do with aerodynamics. Pickup difference can be clearly felt when trying horz bat shots.
« Last Edit: July 22, 2018, 04:46:16 AM by adb club cricketer »
