GM ST30 606
Author Topic: GM ST30 606  (Read 4471 times)
Toby
GM ST30 606
« on: November 03, 2018, 05:40:29 PM »
Picked this bat up off Amazon the other day for £32, weighs 2lb 8oz and has 6 evenly spaced straight grains and a few blemishes as to be expected with this grade.
The bat has a 540mm blade length and 280mm handle length which makes it 30mm shorter in the handle than a standard short handle bat with 540mm blade, i don't think this will be too much of an issue as i'd already shorten my GM Neon's handle slightly by removing the knob from the top of the handle . The only other difference is a slightly thinner handle but this isn't anything that a second grip won't sort out.
The response with an oldish ball and off the mallet is decent but that's to be expect from the GM's i've picked up over the last couple of years.
Here's a comparison between the ST30 ,GM Neon(slightly shorter than standard) and Gray Nicolls Prestige
jayralh
Re: GM ST30 606
« Reply #1 on: November 03, 2018, 07:12:00 PM »
What's edge size on that
alexevo94
Re: GM ST30 606
« Reply #2 on: November 03, 2018, 08:05:31 PM »
That neon looks lovely what grade was that
liscon12
Re: GM ST30 606
« Reply #3 on: November 03, 2018, 08:17:23 PM »
808 surely
Toby
Re: GM ST30 606
« Reply #4 on: November 03, 2018, 09:07:21 PM »
Toby
Re: GM ST30 606
« Reply #5 on: November 03, 2018, 09:13:46 PM »
34mm at the peak and then 12mm at the shoulders and 15mm at the toe
Re: GM ST30 606
« Reply #6 on: November 03, 2018, 09:39:40 PM »
Is the blade full width on the ST30
alexevo94
Re: GM ST30 606
« Reply #7 on: November 03, 2018, 09:44:59 PM »
If you need someone to take it off your hands, I’m here for you 😉
Toby
Re: GM ST30 606
« Reply #8 on: November 03, 2018, 09:46:05 PM »
The GM Book of cricket says 108mm and I’d say it’s bang on that when measuring with a ruler
Re: GM ST30 606
« Reply #9 on: November 03, 2018, 11:16:23 PM »
@Toby - are you very short?
Toby
Re: GM ST30 606
« Reply #10 on: November 04, 2018, 12:33:09 AM »
