SA vs PAK
Pages: 1 2 [3] 4 5 ... 11
Author Topic: SA vs PAK  (Read 24855 times)
mo_town
Re: SA vs PAK
« Reply #30 on: December 27, 2018, 02:32:31 PM »
Pakistan need 50 more runs to make this very interesting.
Novak
Re: SA vs PAK
« Reply #31 on: December 27, 2018, 02:35:50 PM »
A lot would argue there is no point of sarfraz in the test team
One day and 20 20 definite
Novak
Re: SA vs PAK
« Reply #32 on: December 27, 2018, 02:39:36 PM »
Never seen rabada before but the guy is a special bowler
Mister Le Chiffre
Re: SA vs PAK
« Reply #33 on: December 27, 2018, 02:54:46 PM »
It's extraordinary how South Africa produce brilliant fast bowlers at will. Guys only after readmission - Donald, Pollock, Ntini, Steyn, Morkel, Philander, Rabada and potentially Olivier/Ngidi.
Opinions are like assholes...everyone has one.
Novak
Re: SA vs PAK
« Reply #34 on: December 27, 2018, 02:57:01 PM »
They have produced bowlers at a faster rate than Pakistan
mo_town
Re: SA vs PAK
« Reply #35 on: December 27, 2018, 02:59:51 PM »
Seen Olivier bowl before too and he was nothing special then...maybe its just the poor Pak batting lineup which is making him look so good
Mister Le Chiffre
Re: SA vs PAK
« Reply #36 on: December 27, 2018, 03:03:28 PM »
His improvement seems due to putting 8-10kph into his bowling. 130s up to mid 140s in this match
mo_town
Re: SA vs PAK
« Reply #37 on: December 27, 2018, 04:04:20 PM »
Well bowled Olivier. Proved that the first innings wasnt a fluke. This should be an interesting chase.
dt-second-hand-cricket
Re: SA vs PAK
« Reply #38 on: December 28, 2018, 09:35:44 AM »
like the look of Afridi - for 18 he looks a great prospect - his arm and wrist are so elastic like - gets amazing whip through his action
mo_town
Re: SA vs PAK
« Reply #39 on: December 28, 2018, 10:13:19 AM »
Looks like the match is slipping from Pak's hands.
rockymoghal
Re: SA vs PAK
« Reply #40 on: December 28, 2018, 12:10:57 PM »
Pakistan really need to look at the senior batsmen here. The only two guys who scored were Babar Azam and Shan Masood. Sarfraz doesn't warrant a place in the side as a player, let alone the captain. He needs to lead from the front. Sad times for Pakistan test cricket.
csnew
Re: SA vs PAK
« Reply #41 on: December 28, 2018, 12:40:34 PM »
Some much needed runs for amla
Asad S has become a home track bully, appears all at sea away from home. 100-1 to 146-6 is inexcusable on a flat wicket (was the best time to bat in the test match).
Another 3 day test match - batsmen unable to grind knocks out any more
Mister Le Chiffre
Re: SA vs PAK
« Reply #42 on: December 28, 2018, 12:52:26 PM »
Azhar Ali 36 and 0
Asad Shafiq 7 and 6
Sarfraz Ahmed 0 and 0
So in 6 innings Pakistan’s senior batsmen averaged 8.16 between themselves, quite frankly pathetic and you won’t win many matches anywhere with lacklustre efforts like that.
Fakhar is too loose to open in these conditions might be better off at 6 and playing like QdK.
They desperately need Abbas as well. He’s not only the spearhead but he’s capable of restricting the flow of runs which Hasan Ali cannot do.
Re: SA vs PAK
« Reply #43 on: December 28, 2018, 01:54:04 PM »
Nice to see you’re still alive @rockymoghal 😂😂
mo_town
Re: SA vs PAK
« Reply #44 on: December 28, 2018, 01:56:10 PM »
Looking forward to seeing Abbas bowl. I have a feeling that he will struggle in SA conditions where there isnt much lateral movement.
Does Pak have anyone on the bench/in reserves who can reverse their batting fortunes?
