Sand paper Question
Author Topic: Sand paper Question  (Read 2980 times)
Sitonit
Sand paper Question
« on: February 12, 2019, 11:35:27 PM »
So what's a good sandpaper number to remove the dirt and ball marks, and then give the entire bat, a good face lift where the surface becomes smooth?
Re: Sand paper Question
« Reply #1 on: February 12, 2019, 11:48:59 PM »
You'll need more than one grade if you want a smooth finish as well as getting the marks out. For a refurb I usually go 100 - 180 - 240 grit.
Sitonit
« Reply #2 on: February 13, 2019, 03:35:19 AM »
OK sounds good.
Will give it a shot.
Thanks.
LateBloomer
  • Trade Count: (-1)
« Reply #3 on: February 13, 2019, 07:08:56 AM »
Cant help with the sandpaper but I use a squirt of nail varnish remover on a cotton wool pad to clean the cherries off my bats
« Reply #4 on: February 13, 2019, 08:36:19 AM »
If you want a really smooth finish use the grades above plus a specialist finishing paper followed by a specialist polishing paper.
« Reply #5 on: February 13, 2019, 09:29:42 AM »
What grade do people go up to when doing a refurb?
If there are heavy sticker imprints or a lot of residue I start at 120, if not I'll start at 240.
I start om the orbital with 120 and/or 240, then hand sand with 240, 320 & 400. If I'm feeling like I want a really smooth finish I sometimes apply a light coat of linseed then go over the whole blade with 600 grit wet and dry.
@Seniorplayer how much difference does a finishing and polishing paper make compared to just using 400 or 600 grit wet and dry?
And why do I care? After a couple of weeks being used and thrown around in a kit bag the finish is gone anyway...
« Reply #6 on: February 13, 2019, 10:48:15 AM »
More aesthetically pleasing  when players collect there bats also  as the names suggest finishing paper nicer smoother finish to the touch compared to sandpaper polishing paper  a type of glass paper gives the willow a nice gleaming silky  finish  done properly restores bats to original visual conditon.
LukeFramBurton
« Reply #7 on: February 13, 2019, 09:05:12 PM »
I tend to go for 180, 240, 400. I'm going to get myself a buffing wheel to see if I can get a NorthernMonkey style sheen.
« Reply #8 on: February 13, 2019, 09:39:47 PM »
For a new bat I'll go right up the grades, for a refurb I don't think it's worth going over 240. If you go for an as new finish you're going to sand an ounce plus off the bat to do it, so 240 is more than enough. Especially considering all you're going to do is go and hit balls with it anyway!
Coach
« Reply #9 on: February 13, 2019, 09:54:02 PM »
Agree with most on here, Ive got a small orbital sander and usually start with 120 and work to 240. If Im pushing the boat out I might go a bit higher but very rarely. Bat wax and a soft cloth gives a nice finish with a bit of elbow grease
« Reply #10 on: February 13, 2019, 10:07:39 PM »
Nobody's made a Bancroft/Warner joke yet?
« Reply #11 on: February 14, 2019, 07:59:11 AM »
I’m upto 1500 grit these days and I’m still not happy on new bats! As long as batmakers keep finishing on 240grit I’ll be happy
As for refurbs,,, urr shocking how bad some people treat their bats, wouldn’t mind if they scored loads of runs.
As has been said it’s nigh on impossible to get an as new finish without removing loads of wood
I’m trying my best to avoid refurbs
