Suggestions on TK Lam repair
Pages: 1 [2] 3
Author Topic: Suggestions on TK Lam repair  (Read 10885 times)
Komdotkom
Re: Suggestions on TK Lam repair
« Reply #15 on: July 31, 2019, 09:45:35 PM »
I haven't used it for a while, mostly bowling machine work in the winter here so I've got a few Indian made bats for that.
I loaned it to a team mate a few weeks ago for a friendly net session and he was very impressed, but it has the weirdest sound to it. I think it may be close to impossible to spot a laminate on the field visually, but I reckon the noise is a give away.
Komdotkom
« Reply #16 on: October 20, 2019, 08:23:19 PM »
Well, it happened again.
Chasing a bit of medium porridge outside off I dragged the toe on the pitch (astro) while giving the ball the thrashing it deserved. The good news is the ball went for six over cover, bad news is I've folded the corner back again.
The toe on this is very thin on the edges at around 20mm and with my lusty swings and poor execution I'm starting to think that timber may not be the best solution to this issue, the section of 6mm KD marine ply that I used in the last repair broke along with the toe. Clearly the simplest solution would be to stop smashing the toe on the pitch but that's hardly likely so I am considering a fairly unorthodox solution.
I am considering making a titanium lamitoe from 2 sections of 3mm plate tig welded together (6mm plate just isn't available) and then filling the void with a flexible epoxy and micro balloons.
Given that I'm already committing terrible hate crimes against cricket by using a lam in the lofty grades of club cricket in which I play, I can't see any downsides since I'm going to hell anyway for cheating.
Thoughts?
« Reply #17 on: October 20, 2019, 08:27:11 PM »
I wouldn’t do that. If you make the toe really stiff it will shatter
Komdotkom
« Reply #18 on: October 20, 2019, 08:28:57 PM »
Graft a corner in then?
« Reply #19 on: October 20, 2019, 08:59:32 PM »
Add a new photo In and well have a look. But probably
KettonJake
« Reply #20 on: October 20, 2019, 09:06:02 PM »
Never seen the words flexible and epoxy in the same sentence before
jacob@durantcricket.co.uk
KettonJake
« Reply #21 on: October 20, 2019, 09:45:03 PM »
Might be time for the rather unfashionable toe cap.
https://twitter.com/MadeByGrayNics/status/1019568663001739264?s=20
Komdotkom
« Reply #22 on: October 20, 2019, 10:05:24 PM »
There's plenty of flexible epoxy's most of them are for marine applications where the sheets need to buckle and spring back. We use a rigid system for carbon fibre parts but our supplier has heaps of different options, waiting for a call back from the technical guy at the moment with a recommendation but I was thinking about West Systems G-Flex 655.
I'll get a picture when I get home tonight, but it's the same as the last one.
IQ
« Reply #23 on: October 22, 2019, 02:26:21 AM »
I know its not a forum favourite solution but how about fixing the toe as best as possible and threading it. For this sort of damage I have found it to be pretty effective.
Post threading put extra PVA Glue on top of thread. Once the glue dries the thread becomes TIGHT
« Last Edit: October 22, 2019, 02:29:30 AM by IQ »
Komdotkom
« Reply #24 on: October 22, 2019, 02:39:36 AM »
I had thought about binding as a good solution but it's so ugly! I'm a big believer in 'if it's worth doing then it's worth overdoing' so I'll dream up some elaborate and overly complicated solution.
« Reply #25 on: October 22, 2019, 06:21:50 AM »
Cut a couple of cm off the bottom, and if overall length is an issue get a slightly longer handle put in. The bats a cracker, just need to stop hitting things with the toe  :D
« Reply #26 on: October 22, 2019, 09:35:35 AM »
Not hugely surprised by that to be honest! Never been convinced by lamitoes and also wouldn't have used ply. Going to try and give it another go?
Komdotkom
« Reply #27 on: October 22, 2019, 10:23:30 AM »
Why wouldn't you use ply wood? I reckon it's probably the only thing that held the corner on.
I'm interested to hear what other wood could be used for a lamitoe or anything that can be done to improve the quality of the repair.
My thinking was that if I could spread the impact across the width of the blade with a rigid insert the corner would be less likely to fall off.
« Reply #28 on: October 22, 2019, 11:07:32 AM »
Plywood's too rigid and brittle - you may be increasing the strength of the toe a little but you're making it more likely to crack off somewhere, as has happened in the end. Looks to me the willow has moved a bit, as it often does in that spot, and because the ply can't deform with it you've ended up with a blown out toe behind where the ply has cracked. Have seen lamitoes end this way before, I'd guess it's a common result.
You'd possibly want something that will add some strength but ideally compress a little when hit hard, particularly in this case where there's so little willow behind the repair. More realistically I think I'd just use a piece of willow as it's a nice safe option, with a careful choice of non-brittle adhesive. For this particular repair maybe just remove everything rear of the insert (and a bit above that) and put a decent size new block of willow in to replace it.
Just spotted your post about a titanium insert - would end with a totally destroyed toe I'd say! Sandwiching your 1cm of willow between a hard pitch or cricket ball and a piece of ti is only going to have one loser.
IQ
« Reply #29 on: October 23, 2019, 01:47:10 AM »
In that case this is perfect  for you.  :D
Only way to fix that toe for good is to get rid of it.
And nothing says overdoing than replacing a perfectly sound handle.  ;)
How about experimenting with different threads for binding? Had a guy rock up with a toe wrapped in thin BADMINTON Racquet string the other day. I was doubtful but he seemed chuffed by it.
Pages: 1 [2] 3
