RNS Larson bat - knocking do's and dont's?
Author Topic: RNS Larson bat - knocking do's and dont's?  (Read 6116 times)
bigblue365
Re: RNS Larson bat - knocking do's and dont's?
« Reply #15 on: October 20, 2019, 12:53:13 AM »
How many times is oiling (& how much) required?
2-3 times.
Yorkershire
« Reply #16 on: October 25, 2019, 01:55:31 PM »
DO'S - Knock it in absolutely loads
DON'TS - Forget to knock it in absolutely loads
Heed this wisdom!
bigblue365
« Reply #17 on: October 25, 2019, 08:14:22 PM »
70 mins into knocking in process the right hander outside is cracking vertically. I uploaded the images here - https://imgur.com/a/0zcUI92
Not sure what to do next?
Mfarank
« Reply #18 on: October 25, 2019, 09:19:29 PM »
Clear sign of overdried willow. Superglue and sand it down. Then put a couple of layers of fibreglass edge tape and hope for the best
« Reply #19 on: October 25, 2019, 09:50:21 PM »
It’s not that bad at all.  I wouldn’t jump to conclusions. Seems like heartwood - it can crack like that if you whacked it too hard. No big deal - just glue and sand. Edges seem nice and round now - I wouldn’t knock them more.
Jimmy Tiwana
« Reply #20 on: October 26, 2019, 12:44:03 AM »
Agree. My SM I bought last year had an impressive ping even though it started disintegrating during the knocking in process
« Reply #21 on: October 26, 2019, 08:47:59 AM »
Doesn't look like anything to worry about at all, make sure you're not going too hard too early with the knocking in. Finish the process and then give it a little sand down, it'll be fine.
bigblue365
« Reply #22 on: October 31, 2019, 07:08:32 PM »
Followed brokenbat and edge advice(superglue and light sand) and finished 4 hrs knocking. Ping is good now and hoping it will further open up after few net sessions. Applied scuff sheet and edge tape - https://imgur.com/a/9ySeiFg
Psi
« Reply #23 on: October 31, 2019, 07:56:53 PM »
Looks very nice. I would also put edge tape up the edge by the label as this bit is quite susceptible to cracking if you edge it there (through bitter experience this afternoon. Edged a pull shot badly up near the label and it has dented /cracked my new bat. Now fixed with a steam iron, superglue and sanding. Edge sheet now applied 😂
« Reply #24 on: October 31, 2019, 08:02:11 PM »
That’s a nice looking stick
