Cricket spikes cleaning
Author Topic: Cricket spikes cleaning  (Read 1715 times)
Sloggerz
« on: December 27, 2020, 09:56:07 PM »
Still have not cleaned my spikes from the summer.
Whats the best way to remove the dirt from spikes.
jimmy23
Re: Cricket spikes cleaning
« Reply #1 on: December 27, 2020, 10:03:13 PM »
Remove the spikes and put them in the washing machine, put them in a pillow case like you would with trainers. I’ve done this lots of times and works fine.
Sloggerz
« Reply #2 on: December 27, 2020, 10:38:26 PM »
How did you dry them after? Any particular setting to use on machine?
Julesoak
« Reply #3 on: December 28, 2020, 06:26:16 AM »
Don’t ever tumble dry them!
Take out the insoles, stuff with newspaper and put on/near a radiator.
Use a 30 degree wash with an 800 spin, my machine has a sports shoes setting (which I’ve not seen on any others)
SurreySam
« Reply #4 on: December 28, 2020, 12:04:15 PM »
I hand washed mine, as felt a washing machine cycle could beat them up too much and weaken glued and coated areas.
My 22yds looked just like that, maybe a tad worse and got them looking about 85% better. I stripped off the laces and machine washed those in a whites wash, then got a bowl of hot water and a nail scrubbing brush.  Take out the inner soles and submerge into bowl of hot water to wet the shoe, spritz on some Vanish stain remover spray and agitate dirty areas with the nail brush, rinse and then repeat as necessary. Some areas will require working from inside the shoe, where dirt has got behind the plasticised external coating.
I then prop the shoes up vertically with the heels on the ground, to try drain water out the fabric within the toe box area. After about half a day I then squeeze out the last bits of water from the heel. Finally pop them into a warm area, ideally like an airing cupboard but a radiator with hand towel underneath would be ok. You don't want a fierce heat to dry them out too quickly.
Next time I might soak the shoes overnight in a bowl of water and powdered stain remover, like I do my cricket whites to try improve on the results.
jimmy23
« Reply #5 on: December 28, 2020, 01:05:16 PM »
30-60 min wash on 30 degrees.
As mentioned stuff them with newspaper and they will dry in no time.
