ACID
Pages: 1 [2] 3 4
Author Topic: ACID  (Read 17908 times)
Re: ACID
« Reply #15 on: June 21, 2023, 04:49:27 PM »
Do class worlds leading manufacturer by quality or volume?? They are certainly the largest producer but quality certainly not in my view. Nice to see total transparency for a change, not that I would expect anything else from Salix.
I guess I meant largest. Agree about the transparency.
Re: ACID
« Reply #16 on: June 21, 2023, 07:13:30 PM »
It was a junior brand within Salix. @SOULMAN1012 will be able to shed more light but it wasn’t owned by Ben that’s for sure.
Think AK posted some clarification on that on the Salix Instagram.
Re: ACID
« Reply #17 on: June 22, 2023, 10:16:36 AM »
Why can't Salix make big bats themselves? Or they can?
Re: ACID
« Reply #18 on: June 22, 2023, 10:31:43 AM »
They have always struggled to make big bats, I suspect it's to do with moisture content as well as sheer volume of willow ordered
KettonJake
Re: ACID
« Reply #19 on: June 22, 2023, 11:26:08 AM »
The RAW is/was a big bat. I saw plenty of bruisers when I last visited.
The typical Salix shape is quite reserved and traditional, it doesn't mean they can't or don't make big bats though.
jacob@durantcricket.co.uk
Re: ACID
« Reply #20 on: June 22, 2023, 11:30:54 AM »
Don't they grow their own willow?
Re: ACID
« Reply #21 on: June 22, 2023, 12:04:13 PM »
Even if you did - you can't just tell your willow to be low density 😂 Also requires kilns to get the moisture content low enough to make higher volume bats at lower scale weights. (Which I don't think Salix have) Romida for example only take stock that's up to 2lb 10oz max generally. Most of the Salix bats there are pretty small compared to other brands, but I've only ever seen 2 Salixs break prematurely, and they both had storm damage. I suspect the expert craftsmanship and higher moisture contents in general will play a part in that.
Salix are one of the few who won't compromise on width, and also their 'artisan' ways, so their bats will generally look how Kember thinks bats should be crafted, at least from what I've gathered.
I really didn't like the stickers when I first saw them - but agree that the transparency is definitely refreshing. Good to see them continuing to stick to their ways in the sense that they don't want anything to leave that they view as shoddy craftsmanship, and best way to do that consistently while producing to volume is to ensure that they still maintain a high level of control, even if using SS part mades for this range.
Re: ACID
« Reply #22 on: June 22, 2023, 02:39:30 PM »
A little sad that they feel they have to compromise a little tho? The drive for big bats is obviously still evident, so they're maybe trying to meet that demand here, but at the same time having to compromise a little. Or am I reading that wrong? Good to be transparent, but obviously didn't want to put these out under the Salix brand.
I don't mind it either way. I kind of like Salix have always bucked the trend and just made quality bats, big or not by today's standards tho
Re: ACID
« Reply #23 on: June 22, 2023, 03:29:36 PM »
Nice post, Jonny.
Don't get me started on 'wobble seam'.  ;)
Re: ACID
« Reply #24 on: June 22, 2023, 04:55:39 PM »
Not entirely clear but is this maybe a budget offshoot of their main brand?
Demand for Salix seems to keep them pretty busy and their cheapest bats are definitely not budget friendly to your average midweek warrior so perhaps an attempt to bring in some extra business that way while reducing costs with the SS part mades?
The4thStump
Re: ACID
« Reply #25 on: June 22, 2023, 05:49:29 PM »
Any idea what these bats are retailing at?
Aftabius
Re: ACID
« Reply #26 on: June 22, 2023, 08:11:29 PM »
Salix most certainly can make a big bat!!
https://postimg.cc/gallery/Kc7Z2rJ
Re: ACID
« Reply #27 on: June 23, 2023, 07:01:06 AM »
Er, can't see it suggested anywhere by Salix that they're doing these to get bigger bats? Seems much more plausible that this is intended to get them a bit of the lower budget market that they don't currently serve.
thegowerwaft
Re: ACID
« Reply #28 on: June 23, 2023, 07:10:13 AM »
It's also getting people talking about Salix. Clever move mid-season when sales slow down.
Re: ACID
« Reply #29 on: June 23, 2023, 08:42:28 AM »
Sorry, think it may have been an assumption from their initial tagline on Insta 'Big, light, powerful'. Could be wrong obviously and coud be a more budget friendly option.
Pages: 1 [2] 3 4
