Mongoose MMI3
Pages: 1 [2] 3
Author Topic: Mongoose MMI3  (Read 5493 times)
Re: Mongoose MMI3
« Reply #15 on: March 22, 2024, 01:35:04 PM »
You shouldn't need specific handles. Splice to top of handle on an MMi3 is ~39cm so slightly shorter than a regular bat.
Keeley used to use a regular handle and cut 1" off the bottom (leaving a fat splice). Hunts used to cut off the top, so spliced like a normal bat.
Sorry, not sure I follow. They cut 1inch of the bottom of what and are you saying the 39cm is essentially everything which isn't the blade?
Everyone splices differently and I've never seen one, hence why I Said it would be good to see one before making one and taking proper measurements etc.
I've made similar super short blades extra long handles, but with the splice in the blade.
mr_reagan
Re: Mongoose MMI3
« Reply #16 on: March 22, 2024, 07:57:46 PM »
I spoke to them fairly recently. They were not interested in making an mmi.
I guess i will be trawling ebay hoping to find one for reasonable money, certainly not an easy task these days.
Re: Mongoose MMI3
« Reply #17 on: March 22, 2024, 10:20:30 PM »
Surely if you don't have the splice in the handle, you lose a lot of hitting area? Equally, what stops the handle/splice from breaking?
Re: Mongoose MMI3
« Reply #18 on: March 23, 2024, 01:50:30 PM »
Just because there's no splice in the blade, doesn't mean it will ping in that area. If that was the case, all bats would be made like that
Re: Mongoose MMI3
« Reply #19 on: March 23, 2024, 04:52:25 PM »
Other (normal) bats have more hitting area? Wouldn't their balance be completely different if they were spliced in the handle? Wouldn't they be more prone to breakages?
Re: Mongoose MMI3
« Reply #20 on: March 23, 2024, 05:21:54 PM »
Not sure I get where you're coming from mate tbh. You can still hit the ball in the splice area on a normal bat, it just won't go very far. On any bat you only really have a certain percentage of the bat which is really the hitting area.
It will feel different as it is different to a normal bat, but you can still balance it to feel nice
« Last Edit: March 23, 2024, 08:46:39 PM by jonny77 »
Re: Mongoose MMI3
« Reply #21 on: March 23, 2024, 10:21:26 PM »
Structurally, and ignoring dimensions for a moment, isn't the Mongoose just a shoulderless bat with the grip pulled down over the splice?
Re: Mongoose MMI3
« Reply #22 on: March 24, 2024, 12:23:38 AM »
Essentially yeah. The shoulders are dropped down so that the splice is encompassed by the handle and ears and only a minimal amount "protrudes" down into the blade.
Re: Mongoose MMI3
« Reply #23 on: March 24, 2024, 06:44:50 PM »
I’ve made a few and managed to incorporate the splice into the handle.
Think I may still have the first one I made from a hunts standard cleft set up in the early days. Don’t think the Splice was 100% in the handle but wasn’t far off
Generally the main issue is the grip as it’s difficult to find a grip long enough
« Last Edit: March 24, 2024, 06:48:42 PM by Red Ink Cricket »
Tom
    • www.cricketinsight.co.uk
Re: Mongoose MMI3
« Reply #24 on: March 24, 2024, 09:43:32 PM »
Yes, pretty much. Does this drawing help explain @jonny77?
Interesting notes:
- You'll see the portion of the Mongoose which is made up of cane is actually shorter than a regular handle by around 2cm. There is no need for special handles.
- The 'ears' are the portion of willow which protrudes into the handle, this happens on a normal bat and they are bound by string. They can protrude up to 2.5" into the upper "handle" section under MCC Laws.
- You need a similar length of adhesive of cane + willow across both a regular bat and a Mongoose. This results in the Mongoose having willow which protrudes much further into the handle than a regular bat, this is where the law just mentioned comes in.
- Mongoose got round this law with 2 ways. The first was by making a small cut in the willow in the ears (blue pencil), this gave enough separation between the lower portion of the handle and upper portion. Remember the handle can be made from any wood, using willow in the handle is absolutely fine.
- The second way was making use of a sticker to cover some of the lower portion of the splice. To everyone else this just looked like funky grip tape, but it was essential for allowing this cut ^ to happen far enough up the handle/cane joint in order for it not to compromise structural integrity.
« Last Edit: March 24, 2024, 09:47:36 PM by Tom »
Jaffa
Re: Mongoose MMI3
« Reply #25 on: April 08, 2024, 10:06:38 PM »
A few weeks ago I was at Hunts and asked if they could make a MMi copy and they said yes. Just bring it in.
I do feel though the Cor3 is a more usable shape.
mr_reagan
Re: Mongoose MMI3
« Reply #26 on: April 08, 2024, 11:14:20 PM »
The Cor3 is definitely more useable and less of a novelty. Did they give you an idea on how much it would set you back?
    • Neon Cricket
Re: Mongoose MMI3
« Reply #27 on: April 09, 2024, 07:40:47 AM »
I had a Cor3 2nd year of uni that was used for the 'Titans of Cricket' competition, was a cracking bat. For me it was the Cor3 that started to pave the way for all the SB/LH bats you see nowadays IMO.
Mongoose were just way ahead of the curve, and unfortunately until recently, the cricket market in general has always had a level of resistance to any sort of modern change. I'd love to relaunch Mongoose now to be honest!
Re: Mongoose MMI3
« Reply #28 on: April 10, 2024, 02:59:23 PM »
I've got a Keeley made Cor3 and what I think is an SS MMi, the Cor3 is more usable for sure - by current trends it's not even a lot shorter than normal. The MMi does actually hit noticeably further than a normal bat though. My MMi is too light really (2lb7), I'd love to see the damage a slightly heavier one could do!
Jaffa
Re: Mongoose MMI3
« Reply #29 on: April 11, 2024, 09:01:52 PM »
Played against a bloke who had a huge MMi. He said it was 3lbs and he could bat. He caused a lot of damage.
Pages: 1 [2] 3
