Marking out your guard!
Pages: 1 2 [3] 4
Author Topic: Marking out your guard!  (Read 8430 times)
stubbzy
Re: Marking out your guard!
« Reply #30 on: February 11, 2011, 06:53:51 PM »
i dont check my guard, i just remark it, i only scratch about 3 times, merely routine and routines help you concentrate
roco
« Reply #31 on: February 11, 2011, 06:57:42 PM »
I mark my guard with a v on leg once then don't bother with it again unless I can't see it but I always have the face of the bat facing the off stump
kenbriooo
« Reply #32 on: February 11, 2011, 09:26:10 PM »
Ask for 1 - which always allows you to quickly assess the standard of the umpire as occasionally they don't know what you mean!
Tend to Mark a line from the crease back towards the stumps as it tends not to get trod on to there so I can keep remarking it as and when. I'll also make a Mark about a foot in front of the crease going diagonally towards fine leg. I quite often like to bat in and out of my crease so I find it helpful to have the 2 markings.
Sure the groundwork does not appreciate it tho!
pacman75cricket
« Reply #33 on: February 12, 2011, 04:41:52 PM »
Make one mark & remark when necessary.
As groundsman what is a irritating is keepers making a gouge on  off stump.
Tumo
« Reply #34 on: February 12, 2011, 06:08:29 PM »
I don't mark it anymore, I ask where 2 is and then go from there. Someone before has no doubt gouged a canyon on middle, so I have a decent idea of where everything is.
chris_1978
« Reply #35 on: May 06, 2011, 08:16:57 PM »
I mark out with a stud, and then next over when at the non strikers end i do a Chanderpaul with the bail.  That hole will the stay there for longer than any other scrape.  Just dont do it when you take guard, youll get sledged.
Coach
« Reply #36 on: May 06, 2011, 08:22:38 PM »
Chris, welcome to the forum i see this is your first post however if you look at the date of the last post it was a while back, check the dates in future it will keep the admin guys happy which is always a good thing.
Wills
  • Seams too good to be true
« Reply #37 on: May 06, 2011, 08:27:48 PM »
Just wondering what would you do if you came to a relatively used wicket and came to somewhat of a ditch because of all the guard marking.
alexrickyponting
  • WWTD
« Reply #38 on: May 06, 2011, 08:30:19 PM »
mark guard within crease where ground is better most likely
mattw
    • PRYZM Cricket
« Reply #39 on: May 06, 2011, 08:37:18 PM »
I was playing a game the other day and someone from the opposition put his bat on the ground and lined it up with the stumps and then marked his own guard. At least I guess you know the ump hasn't given you a dodgey guard.
Talisman
  • Trade Count: (+76)
« Reply #40 on: May 06, 2011, 11:17:29 PM »
Don't take a guard, no need unless you are weak mentally, watch the ball instead, works 60% of the time all the time.
Johng
« Reply #41 on: May 07, 2011, 12:14:18 AM »
LOL only from you Mike!!!
Talisman
« Reply #42 on: May 07, 2011, 06:49:03 AM »
I was actually told by an Aussie coach with Somerset years ago that if you need to know where your stumps are they are the large wooden sticks 3 feet away, also the bowler will never deliver the ball from exactly the same position 2 balls in a row so why would you stand in exactly the same place? I stand where I feel happy and don't worry about anything else, don't get too hung up over scratching and re marking a line in the dirt, there are far more important things to concentrate on. Free your mind.
« Reply #43 on: May 07, 2011, 07:12:45 AM »
I will try this, never use a mark in nets and never seem to be bowled. Mind you nets for me is all about having a slog!
« Reply #44 on: May 07, 2011, 08:05:17 AM »
Seen it alot haha. I generally do it before asking for my guard, saves a bit of time for the ump if I've got it right.
Pages: 1 2 [3] 4
