Movember --- Ask the bat maker
Pages: 1 ... 3 4 [5] 6 7
Author Topic: Movember --- Ask the bat maker  (Read 123711 times)
Re: Movember --- Ask the bat maker
« Reply #60 on: November 23, 2010, 05:17:36 PM »
It leaves soft spots if not correctly done ---- so for example some may have a soft toe [others on here can confirm or deny for real world examples]
Cheers.
Another questions;
Why do bats have bow? What are benefit of bow and does it affect the sweetspot length/position by any chance?
Monty Bodkin
« Reply #61 on: November 23, 2010, 05:27:01 PM »
Andy - perhaps you would explain MMI the centre of percussion and how they relate to the sweet spot on a bat
« Reply #62 on: November 23, 2010, 05:27:55 PM »
A bit of background info - I've got a Honours Degree in Mechanical Engineering
That'll explain the Monty Python recognition. I'm essentially a MechE too...
jonpinson
« Reply #63 on: November 23, 2010, 07:01:26 PM »
What are your prices for the two limited edition grades you do? Answer via pm if you prefer. I need to set some budgets.
SAF Bats
    • San Andreas Fault
« Reply #64 on: November 23, 2010, 09:49:29 PM »
Cheers.
Another questions;
The bow I'd imagine was originally there for aesthetics. The bow effects the balance of a bat and therefore the sweetspot and it position but only a techie one the Centre of percussion
Email: cricket@safbats.co.uk
SAF Bats
    • San Andreas Fault
« Reply #65 on: November 23, 2010, 09:53:24 PM »
Hi Monty great 1st post.....
The centre of percussion will shift based on balance, bat weight and swing speed etc, this will move the COP, as you probably know asking a question like that, higer or lower. The same way adding grips to a handle or shaping a bat in certain way
« Last Edit: November 23, 2010, 09:57:39 PM by SAF Bats »
SAF Bats
    • San Andreas Fault
« Reply #66 on: November 23, 2010, 09:54:15 PM »
LE is currently £220 - Inaugural Willow is POA as I get about 3 pieces in a year
Monty Bodkin
« Reply #67 on: November 23, 2010, 10:03:31 PM »
Thank you - as a follow up maybe you would explain the coefficient of restitution and how, if at all, you are able to make use of it in your pressing process?
« Reply #68 on: November 23, 2010, 10:13:30 PM »
I think we did an entire thread on that previously?
SAF Bats
    • San Andreas Fault
« Reply #69 on: November 23, 2010, 11:11:27 PM »
Coefficient of Restitution or Apparent Coefficient of restitution Monty?
RoCo Da Pixie
« Reply #70 on: November 23, 2010, 11:21:51 PM »
Andy might of found his soul mate on this forum with monty
Monty Bodkin
« Reply #71 on: November 23, 2010, 11:31:34 PM »
Interesting. I had not considered that aspect and shall ponder further. Clearly the bat hitting ball involves a collision somewhat different to dropping a ball on the bat or hitting a bat with a mallet.
So how might that be worked into how you determine the optimum press?
jonpinson
« Reply #72 on: November 23, 2010, 11:35:51 PM »
I think Andy has despaired of our ignorance and has created another account so he can talk these things over with someone who understands :D
SAF Bats
    • San Andreas Fault
« Reply #73 on: November 23, 2010, 11:38:48 PM »
Well if I'm honest to ask a question about Mass Moment of Interia [MMI] and Centre or Precussion is quite a clever question but you need to understand they are related as one, MMI, effects the other, otherwise you wouldn't put the 2 together.  It wasn't just a wild guess or lucky question!
Saying that, then to ask a question about CoR [or ACoR] and pressing after a question like that is a bit stupid, as the answer is simple because pressing is related to rebound. So if you quote coefficient of restitution you should know this, therefore making the question like I said a bit stupid
EDIT: Monty may I was being a bit harsh here it isn't a stupid question I missed the bit about "If at all" so I appologise
Please combine this answer with the answer to your second question re: Optimum pressing
« Last Edit: November 24, 2010, 09:22:32 AM by SAF Bats »
« Reply #74 on: November 23, 2010, 11:44:46 PM »
Thank You :)
