Pages: 1 [2] 3 4
Author Topic: Pro's Bats  (Read 8975 times)
thedon
Re: Pro's Bats
« Reply #15 on: December 07, 2010, 10:00:01 PM »
Tom, whereabouts in London do you net?
We also have to give consideration that pros will net nearly everyday, reducing the lifespan of their bats
Re: Pro's Bats
« Reply #16 on: December 07, 2010, 10:05:16 PM »
I have to say I think this is largely a load of tosh. The reason pro bats seem better is because the people using them play more, have better timing and more ability than the rest of us.
A lot of bats are all the same - it is the person using them that makes the difference.
johan95
  • Trade Count: (+105)
Re: Pro's Bats
« Reply #17 on: December 07, 2010, 10:10:03 PM »
Why would the pro's bats be pressed differently? We are always told that our bats are pressed to perfection etc so why are theirs done any differently... I'd hazard a guess at the only real difference between ours bats and the pro's would be grain structure and density.
Have had a hold of Graham Napier's 158* 20/20 bat, extremely heavy and would require serious guns to wield it!!
True, but ask PW88 and Simmy about it, asked they asked Rob Pack this question: the bats are pressed sifter to ensure maximum ping, as all pros care about is performance, not durability, hence they have 4-5 bats in their bag/locker.
Buzz, you're definitely right sbout the player part. Sachin could bat with a plank and still get runs no doubt!
niceonechoppy
Re: Pro's Bats
« Reply #18 on: December 07, 2010, 10:12:28 PM »
The way in which a bat is pressed determines, or at least is a factor of, responsiveness of the blade. By making the bat be pressed in such a way that no netting or practice with it is required allows best possible performance. By standardly pressing them, I believe you can reduce performance in exchange for longevity.
I am not doubting that you are correct, however that would be my guess on so called Pro bats.
GJ
Re: Pro's Bats
« Reply #19 on: December 07, 2010, 10:25:18 PM »
I think we established a while ago as there being no such thing as 'pressing a bat softly'. The bat maker should have an idea when pressing a bat of what will be the best and this will stay the same for all. Density is the only real factor that would significantly increase the performance.
johan95
Re: Pro's Bats
« Reply #20 on: December 07, 2010, 10:30:02 PM »
This could be a question for one of the batmakers on here to clear up! Please do oblige!
Re: Pro's Bats
« Reply #21 on: December 07, 2010, 10:58:15 PM »
My pro bat is lovely!
niceonechoppy
Re: Pro's Bats
« Reply #22 on: December 07, 2010, 11:02:20 PM »
It which case, I am mistaken. Learn something new everyday...
johan95
Re: Pro's Bats
« Reply #23 on: December 07, 2010, 11:05:21 PM »
What bat Is it tim: i'm curious to know!
Washington
Re: Pro's Bats
« Reply #24 on: December 07, 2010, 11:10:06 PM »
If a pro bat is pressed soft to increase performance then why not, not press a bat at all?? I think soft pressing is the biggest mis-information there is about bat making!
Formerly CustomDan21
jonpinson
Re: Pro's Bats
« Reply #25 on: December 07, 2010, 11:11:56 PM »
Surely with no pressing the damage caused by each ball strike would quickly render the bat useless. We all know how soft unpressed willow is, the tiniest touch against anything and our lovely new bat is dented.
Washington
Re: Pro's Bats
« Reply #26 on: December 07, 2010, 11:25:42 PM »
Yes of course jon but what im saying is thats the difference? If a pro is after performance then why not choose a non pressed bat? My interpretation of pressing is that it actually increases the performance of a bat, if done correctly! So in essence there is no such thing as soft pressing, merely correct pressing . . . .
jonpinson
Re: Pro's Bats
« Reply #27 on: December 07, 2010, 11:27:41 PM »
Yeh I agree, totally unpressed will be dead I think.
Tom
    • www.cricketinsight.co.uk
Re: Pro's Bats
« Reply #28 on: December 07, 2010, 11:36:05 PM »
Are pro bats pressed soft or are just some shop bats pressed hard to reduce returns?
Bats are now pressed softer than they were years ago to get more performance (bats used to be soaked in Linseed oil to soften them up), but there is a point where pressed too softly that performance can drop. There's an optimum pressure for each clefts performance.
« Last Edit: December 07, 2010, 11:42:49 PM by Tom »
Re: Pro's Bats
« Reply #29 on: December 08, 2010, 10:47:32 AM »
Look for Norbs discussion on the Coefficient of Restitution and you'll understand that the ping off a non-pressed bat will be lower than a pressed bat, however the change of a momentum imbued by a softer bat is greater through a longer period of contact.
Where's Norbs when you need him ;) ?
Pages: 1 [2] 3 4
