Oval and Round Handle.
Author Topic: Oval and Round Handle.  (Read 15738 times)
i12breakfree
Re: Oval and Round Handle.
« Reply #15 on: December 10, 2019, 11:30:39 AM »
 :o :o :o
True
I did not check the date and was surprised that after owning thousands of bats why @Cover_Drive was asking now about handle shapes
sachin200
« Reply #16 on: December 10, 2019, 03:15:17 PM »
I think oval handle reduces twisting which also imparts more power for off Center shots. This also mean that you don’t need monster edges. Also a thicker oval handle reduces tight bottom hand grip which in theory makes you avoid swish across the line too often (remember Adam Gilchrist - he used extreme oval handle and squash ball in his bottom hand). Other than that, it is always down to preference and these aren’t hard and fast rules. Virat Kohli used to use round handles but he switched to tapered oval handles around 2014-2015 and he is still one of the most wristy players going around. On the negative side, since you are using more of first two fingers on your bottom hand with the oval handle, a long innings always leaves these two fingers and the webbing between them of my bottom hand a bit sore and tired. I guess it can always be improved by practicing with grip exercisers.
Tendulkar never used an oval handle and his strokes were very well defined and straight whereas Mohammad Azaruddin used to get bats made by JM (extreme oval) and he was as wristy as it gets. In nutshell, use what makes you score big and feels natural.
« Reply #17 on: December 11, 2019, 05:12:26 PM »
:o :o :o
True
Lol, 2011. I have gotten grey hair by now.
Sitonit
« Reply #18 on: December 16, 2019, 01:13:55 AM »
Personally, I abhor oval and semi oval handles.
My problem is with the explanation behind the oval handle, which seems more of an oxymoron, where we are told that a semi oval or an oval handle reduces the slip and twisting and turning of the handle in hands. And hence when you play a straight drive, you get a more firmer grip and more power behind your shot.
Here is my logic,
First, if the bat slips in your hands? well, excuse my French but you are wuss. Don't play cricket with such weak muscles and such low energy levels where you can't hold the bat with a firm enough grip.
Second. you DO NEED to open the bat's face to play shot like a square cut, for example, and the round handle helps maneuver the bat A LOT easier than an oval, semi oval or a square or a pentagon or a hexagon shape. You see what I mean?
« Reply #19 on: December 16, 2019, 10:29:26 AM »
All sorts of wrong - the main reasoning behind an oval handle is because it fits the combination of proper cricket technique and the shape of the human hand better. And I'd expect anyone who opens the face to square cut to get caught between point and gully a lot!
« Reply #20 on: December 16, 2019, 01:56:07 PM »
There's some nonsense gets spouted on here!
Have you ever watched a slow motion replay of a pro playing a shot? Their bats constantly twist in their hands when they hit the ball, I guess they should all give up playing cricket because they're not able to defy the laws of physics...
Sitonit
« Reply #21 on: December 16, 2019, 03:07:51 PM »
Bradman and Sobers played with round handles. Many, many Asian greats also played with a round handle.
It could be a personal choice and I don't oppose to whoever likes them but IMO, oval or semi oval handle means zilch.
Psi
« Reply #22 on: December 18, 2019, 10:39:56 AM »
I reckon oval is easier for an amateur or beginner to control and stop the right hand taking over and causing a cross bat shot. But if you are a wristy player making lots of pull and cut shots you might prefer round handle.
alexhilly1492
« Reply #23 on: December 18, 2019, 11:01:07 AM »
or just pick a bat up if ir feels right use it?
i prefer the feel of a more oval shaped handle than round but that doesn't mean i cant play all the shots i need to, all this about being able to play certain shots better or worse because of handle shape is quite frankly a load of rubbish, it all boils down to how the bat feels in your hand, just use whatever you prefer and get on with it
BB: 7-4-9-5, 7.3-0-29-5
Psi
« Reply #24 on: December 19, 2019, 12:29:07 AM »
Yes, true I'm sure to a large extent. I didn't mean to say that only beginners like oval handles... Think about golf. Exactly the same issues apply about not letting the right hand take over during the swing (causes a curved 'hook' shot, but they don't make oval club handles (at least they didn't when I last bought a set)) .
Sitonit
« Reply #25 on: December 20, 2019, 12:27:32 AM »
That's actually an interesting thought. Why aren't the golf club handles not oval or semi oval? Don't they provide "stability", "slip control:, "twist control", "firm grip" etc?
