Author Topic: Causes of fatigue  (Read 3886 times)
tommo256
Causes of fatigue
« on: March 09, 2011, 10:19:40 AM »
Hello guys,
im doing a college assignment and need help ib what are the causes of fatigue?
Lee
Simmy
Re: Causes of fatigue
« Reply #1 on: March 09, 2011, 10:22:32 AM »
« Reply #2 on: March 09, 2011, 10:23:42 AM »
having a small child who doesn't sleep all night.
Canners
  • go hard or go home
« Reply #3 on: March 09, 2011, 10:40:05 AM »
12 hour shifts and not enough sleep
Johng
« Reply #4 on: March 09, 2011, 10:42:39 AM »
Smoking to many cigarettes before I bat
Simmy
« Reply #5 on: March 09, 2011, 10:47:17 AM »
g/f poking u in the side for snoring every hour lol
justnotcricket86
« Reply #6 on: March 09, 2011, 11:53:14 AM »
8 pints of the black stuff, 20 benson and a bucket of dry roasted should do the trick
Byo
« Reply #7 on: March 09, 2011, 12:04:03 PM »
Being middle aged and overweight!!!
peplow
  • Trade Count: (+77)
« Reply #8 on: March 09, 2011, 03:31:48 PM »
1. Lactic acid build up
2. dehydration
3. Glycogen depletion
4. reduced rate of atp synthesis
5. low calcium levels
6. low levels of ach
7. Overheating (thermoregulation!)
i guess thats what they'll be after if its sports course, as thats what my a level pe was :) shocked i can remember!
« Reply #9 on: March 09, 2011, 03:47:06 PM »
2. dehydration
Surely 1, 2, 3 and 7 are symptoms of doing something else? Scoring a double hundred? Running a marathon in 25 celsius heat, bowling twenty overs in the west indies, etc...
peplow
« Reply #10 on: March 09, 2011, 03:50:45 PM »
not understanding tim?
those are the 7 always given...
« Reply #11 on: March 09, 2011, 04:24:03 PM »
Maybe, but you get Lactic Acid build up from running 20 odd miles, so they aren't really the causes of fatigue, just the initial symptoms that you are likely to end up fatigued because, surprise surprise, running 20 odd miles is really hard! Funnily enough, that's also the point at which you generally find that you hit the wall, which is caused by glycogen depletion because you have exhausted your supplies by, yes you guessed it, running 20 odd miles!
I know I'm playing Devil's Advocate, but the root cause of the fatigue is not the list, it's the activity that causes the list in the first place!
peplow
« Reply #12 on: March 09, 2011, 04:28:09 PM »
but you could go to such a molecular level with it all, as everything is caused by something. Lactic acid isnt a symptom, its a cause, as lactic acid fatigues you, not you get fatigued and then get lactic acid.
The other way of looking at it is to name every activity in the world you could get fatigued from, which it certainly isnt that, as its pretty muh anytihng in the world.
Lactic acid is just a posh way of describing oxygen debts which is a cause of fatigue.
peplow
« Reply #13 on: March 09, 2011, 04:29:42 PM »
but you could run a mile and not be fatigued? and someone else could run a mile and be f*cked, non-fatigued wouldnt be so because none of the list has taken place... (not likely!)
so its not a specific activity causing it, its the one or more things on the list that are causing fatigue. no?
« Last Edit: March 09, 2011, 04:31:30 PM by peplow »
« Reply #14 on: March 09, 2011, 04:43:50 PM »
In order to suffer "catastrophe" fatigue, you have to use up various metabolites and liquids. The root cause of your fatigue is the activity that has caused you to do this.
However, according to the "Central Governor Theory", fatigue is not generally caused by these cited items. It's caused by the brain reacting to the feedback mechanisms within your body, causing you to reduce the amount of activity to avoid this catastrophic situation.
As a result, true exercise related fatigue is in fact a result directly of the exercise and the way your brain deals with it and not the list. There are a number of studies that reflect this. More importantly, sprint finishes wouldn't be possible in endurance events if catastrophic fatigue had really set in...
