Author Topic: shoo goo  (Read 2153 times)
shoo goo
« on: March 23, 2011, 10:50:39 PM »
Who uses it and where do you apply yours? Toe, toe and face???
johan95
  • Trade Count: (+105)
Re: shoo goo
« Reply #1 on: March 23, 2011, 11:15:16 PM »
peplow is an expert on the subject Mark. I'd think toe only...
Canners
  • go hard or go home
Re: shoo goo
« Reply #2 on: March 24, 2011, 12:57:36 PM »
i think your better off with a toe guard personally
Re: shoo goo
« Reply #3 on: March 24, 2011, 01:10:21 PM »
When I got my new bat from Kippax they put anti scuff on the face and oiled the toe. They add weight, fall off and aren't as effective as linseed oil.
mattw
    • PRYZM Cricket
Re: shoo goo
« Reply #4 on: March 24, 2011, 01:49:25 PM »
I put shoe goo on my bats, except for my new talisman which already had a toe guard on it - however I feel as though it'll be hard running my bat in with the toe guard as it's a bit bobbly so there will be a lot of friction between the ground and the bat when im running it in.
I like to protect the toe of my bats quite a bit just incase i get a fast yorker and it splits it and I don't like toe guards so I found out about shoe goo and experimented with an old bat first.
For best results I feel as though it's best to add it (only onto the toe) a layer of it at a time and then sculpt it once its started to dry a bit as it's more managable and easier to mould into the shape you want it. This then allows you to put the bat upside down and then leave it to dry without worry about the SG sliding down the bat.
I've got some examples of SG that I've added to my bats, I don't like a lot of shoe goo on it but just enough to give it a decent covering so that it protects without adding too much weight. The only problem is that every so often you'll have to add to it as it wears away quite quickly (with the way I tap my bat anyway).
This is my Joker, I haven't used it since I applied the SG.
This is my Solitaire and I have had about 6/7 net sessions with it after I first applied the SG.
Beachcricket
Re: shoo goo
« Reply #5 on: March 24, 2011, 03:36:57 PM »
Shoe Goo is far cheaper in the long run and works just as well. Easy to apply and the layer can be as thick or thin as you like. I've covered the equivalent of 8 bat toes and I've still not used a whole tube.
Re: shoo goo
« Reply #6 on: March 24, 2011, 03:41:31 PM »
As far as I am concerned Shoo Goo is not worth it and there is a reason bat manufacuters these days put a toe guard on a bat. I apprecaite if they are fitted badley or with the wrong glue they can come off - but on the bats I have they have lasted and the really protect the most vulnerable part of the bat.
Re: shoo goo
« Reply #7 on: March 24, 2011, 07:42:54 PM »
I cover the toe and put 1cm on the bat face too
