Re: Snapped SAF :( - REPLACEMENT RECEIVED - UPDATE
Pages: [1] 2 3 4
Author Topic: Re: Snapped SAF :( - REPLACEMENT RECEIVED - UPDATE  (Read 9714 times)
razor2000nz
« on: April 16, 2011, 08:38:39 PM »
Evening all,
I was using my Erus today and things were going very well until i got a knee high full toss and I put it straight down long off’s throat, at the time i thought the bat had made a different noise to what it had been making when i was hitting the ball earlier in the innings.
When i got back to the changing rooms i discovered why there was a different noise......the bat had completely snapped across the back and around to the front.  :(
There are no seam indents on the face of the bat, so it has been knocked in properly.
Have emailed Andy at SAF about my problem...
Here are some pics
« Last Edit: June 21, 2011, 07:34:23 PM by razor2000nz »
Lefty's favourite shot - Cow Corner
Tumo
Re: Snapped SAF :(
« Reply #1 on: April 16, 2011, 08:40:14 PM »
Have to say mate, that just looks like rotten luck!
Jenko
Re: Snapped SAF :(
« Reply #2 on: April 16, 2011, 08:44:21 PM »
Spewing!!!! How old was it mate?
And you got out in the process....rotten luck indeed!
niceonechoppy
Re: Snapped SAF :(
« Reply #3 on: April 16, 2011, 08:52:43 PM »
I had a similar crack in a Salix bat. When I sent it to them they said it was a fault in the willow as it isn't meant to crack down the back, so they sent me a new one. Hard luck.
razor2000nz
Re: Snapped SAF :(
« Reply #4 on: April 16, 2011, 08:53:44 PM »
brand new, brought it as my xmas present form myself
razor2000nz
Re: Snapped SAF :(
« Reply #5 on: April 16, 2011, 08:55:14 PM »
this isn't down the back, this is across the back and around to the front
jimba101
Re: Snapped SAF :(
« Reply #6 on: April 16, 2011, 08:58:06 PM »
Can't be much holding that together!
Jenko
Re: Snapped SAF :(
« Reply #7 on: April 16, 2011, 08:59:05 PM »
Hopefully Andy gets back to you soon mate....that really sucks for you :-(
pacman75cricket
Re: Snapped SAF :(
« Reply #8 on: April 16, 2011, 09:18:01 PM »
Had a bat break similar years ago apart from half the bat nearly hit square leg.
Sure Andy will sort you out as was in contact re how bat was doing + this was a bat bought 12 months ago
razor2000nz
Re: Snapped SAF :(
« Reply #9 on: April 16, 2011, 09:36:51 PM »
so do I, as I'm off to Tenerife on monday for a week. luckily i have this bulldog (and my old bat) to use when i get back, although the bulldog isnt knocked in yet
Re: Snapped SAF :(
« Reply #10 on: April 16, 2011, 09:40:30 PM »
if you need it knocking when whilst your away mate look at my products
http://custombats.co.uk/cbforum/index.php?topic=11095.0
razor2000nz
Re: Snapped SAF :(
« Reply #11 on: April 16, 2011, 09:46:15 PM »
could be an option, are citylink/parcelforce open on sundays??
Talisman
  • Trade Count: (+76)
Re: Snapped SAF :(
« Reply #12 on: April 17, 2011, 06:53:11 AM »
Just a handle fault, it is always a risk when splicing that a fault line can occur, nothing wrong with the way it is made or used, just bad luck.
kieranl73
Re: Snapped SAF :(
« Reply #13 on: April 19, 2011, 11:57:16 AM »
I did this to a charlie french of mine last year and when i took it back to them all they said was it was a faulty piece of willow, apparently for a bat to break like that is a 'once in a lifetime thing' haa
thedon
Re: Snapped SAF :(
« Reply #14 on: April 20, 2011, 09:56:03 AM »
any update on this?
Pages: [1] 2 3 4
