Author Topic: Batting Drills  (Read 1342 times)
awesomeadil
Batting Drills
« on: May 03, 2011, 10:19:40 PM »
Hi,
What kind of drills can I do at home to improve my batting! I was in the nets on monday. I was able to play shots but not able to middle it!
Best Bowling 0/9
Kaz092
  • Don't drop short mate !!!!!!!!!!!
Re: Batting Drills
« Reply #1 on: May 03, 2011, 10:25:56 PM »
Hi,
Shadow batting in front of the mirror works wonders, have a look at your backlift and stuff make sure its coming down straight
Another thing I do which helps is line up some balls on middle, outside off and on the leg side and practise leading with your head as your body will follow
Just good excercises to tune the muscle memory
Hope the season goes well for you fella
Thanks
Kaz
Re: Batting Drills
« Reply #2 on: May 04, 2011, 07:56:43 AM »
practice batting, using a stump and a tennis/golf ball - throw the ball against a wall and play your shots, it will help your timing no end.
The stump and golf ball don bradman technique is pretty hard.
