Author Topic: opening the batting  (Read 2293 times)
kalph
opening the batting
« on: May 22, 2011, 11:50:03 AM »
Ok guys,
 im opening the batting tommorow night in a t20 never done it  before whats your tips on it?
Number4
Re: opening the batting
« Reply #1 on: May 22, 2011, 12:00:17 PM »
Play to your strengths...
« Reply #2 on: May 22, 2011, 12:43:26 PM »
firstly read the other thread on opening the batting and if you still aren't sure... stay still watch the ball and don't premeditate your shots.
Canners
  • go hard or go home
« Reply #3 on: May 22, 2011, 12:53:18 PM »
my thoughts on opening are.....
bat with the intention of not getting out, your job is to see off the opening bowlers and the new ball.... dw about the runs they will come by just putting away the bad ball
20/20 is a different game all together so once you feel like your in you can start to play more shots but id say your aim is to be in after 10 overs at least, nothing worse than being all out in limited over cricket
captainofcricket2011kse
« Reply #4 on: May 22, 2011, 02:24:13 PM »
In t20 one of your top 3 have to bat through! Because even if you have 20 or 30 after 15 overs you can go on to score 60+ whereas someone who is coming in will struggle to just tee-off strsight away!
I would love to bat against my own bowling
langer17
« Reply #5 on: May 22, 2011, 02:36:52 PM »
I agree that an opener's main job is to see off the openers and the new ball. I don't agree that you should bat with the intention of not getting out, because you then become too defensive and wont score any runs. My view is that you should bat with the intention of playing the balls and conditions on their merrits.
But opening in 20/20 is different. I open in 2 day and 1 day games, but in 20/20 I usually bat 5-7 as I'm not a power hitter, but I can come in and push it around while still getting boundries off the bad balls. So I'd say just play the conditions and each ball on it's merrit's and you should be right.
« Last Edit: May 22, 2011, 02:39:18 PM by langer17 »
Canners
« Reply #6 on: May 22, 2011, 02:46:40 PM »
i meant dont worry about hitting the decent balls because you will get enough bad balls... i should have said play every ball on its merrit like you have stated.
langer17
« Reply #7 on: May 22, 2011, 02:53:17 PM »
All good, I should have known that's what you meant, lol :P
Nickauger
« Reply #8 on: May 22, 2011, 05:02:54 PM »
Give it a good good hit! Look to play in the v. Don't worry about keeping it down and hit out or get out! No point in wasting 35 balls for 20 odd. Either that or look to bat the whole innings at a run a ball, and let everyone bat around you.
Apple
« Reply #9 on: May 22, 2011, 06:56:22 PM »
main thing for me in 20-20 = run a ball. good balls drop them for one, hit the gaps, run hard, run really hard, shots that would normally only be run for one, pelt two.
ianbuchanan
« Reply #10 on: May 22, 2011, 07:05:13 PM »
Keep it simple. The runs will come, just play straight :)
Colesy
« Reply #11 on: May 22, 2011, 07:05:59 PM »
Play on instinct.
« Reply #12 on: May 22, 2011, 07:08:11 PM »
We play alot of T20 cricket and here's my tips:-
1. 20 overs is longer than many people think - don't panic about scoring quickly.
2. Good bowling still requires playing out, treat it like a normal game but still look for the singles.
3. Look for a boundary an over + singles against the weaker bowlers, you don't have to take many risks to post 150+ in 20 overs.
4. As others have said, play to your strengths and back yourself as 20/20 does require calculated risk taking
5. Disagree that openers have to see out the opening bowlers, bat 10 overs or the innings. You have to setup a platform of ideally 5-6 an over for the first 6-8 overs, but if your side is decent you'll have big hitters to come then up the tempo. If your 40-50 off 7/9 overs get on with it!
« Last Edit: May 22, 2011, 07:11:02 PM by uknsaunders »
