Author Topic: Breaking the Wicket  (Read 6669 times)
Johnny
Re: Breaking the Wicket
« Reply #15 on: June 20, 2011, 11:05:15 AM »
...I was only thinking about run outs
Black Cat Cricket
« Reply #16 on: June 22, 2011, 09:26:12 PM »
And finally, it's interesting to note that the whole business of pulling the stump out and tapping the ball on it is actually complete rubbish, you just need to remove it from the ground.
no, it says in any of the ways stated in (1), above, the most likely, and only feasible way, is by someone also holding the ball (with ball touching stump).
Just re-read, and I didn't quite understand your original post.  If you were implying that you didn't need the ball to be involved, I think you do. If you were actually referring to the nature of the breaking of the wicket (with the ball), then what I put above is irrelevant!
« Last Edit: June 22, 2011, 11:38:49 PM by BlackCatCricket »
richthekeeper
« Reply #17 on: June 22, 2011, 10:09:36 PM »
indeed, so you can essentially smash it clean out of the ground and that counts. no need for an "excaliber" type removal.
