Author Topic: You Are the Umpire.....  (Read 13296 times)
Re: You Are the Umpire.....
« Reply #15 on: July 06, 2011, 09:44:29 AM »
Not out. you would have to remove the stump from the ground with the ball in hand for it to be out
Number5
« Reply #16 on: July 06, 2011, 09:44:48 AM »
When the wicket keeper has come into contact with the stumps, has he removed them from the ground with the force of his motion?
  No.
Tumo
« Reply #17 on: July 06, 2011, 09:45:14 AM »
If they run a leg bye both batsmen can still be run out regardless if it is then called a dead ball.
I was making the point that you can, contrary to some people's views on here, call a dead ball AFTER the ball was bowled. Nothing more.
« Reply #18 on: July 06, 2011, 09:52:37 AM »
Yes in the case of balls slipping out of the hand in delivery. Surely not once the batsman has hit it and the ball is in play in the field? Then again, what point do you consider a dead ball inappropriate to call? Very tricky!
« Reply #19 on: July 06, 2011, 09:52:37 AM »
Can't just knock them out mate, you have to have the stump in your hand and the ball in the other
No, you don't. Law 28.1.(a).v:
Quote
1. Wicket put down
(a) The wicket is put down if a bail is completely removed from the top of the stumps, or a stump is struck out of the ground,
(v) by a fielder with his hand or arm, providing that the ball is held in the hand or hands so used, or in the hand of the arm so used.
Number5
« Reply #20 on: July 06, 2011, 09:54:29 AM »
Here's one for the wicket-keepers and those who think they know the Laws of Cricket......that's all of us, right?
The scores are tied and it's the last ball of the match.  The ball is hit firmly towards square leg and the batsmen set off for a run. The bails are blown off by the wind as the ball is being thrown to the wicket-keeper. The wicket-keeper catches the ball and brings his gloved hands into contact with the stumps and appeals as the diving batsman has not made good his ground.
What's your decision umpire?  Hurry up, the fielding side are glaring at you, the batting side are lined up in front of the pavilion....everyone is watching YOU!  Decision time....
Answer: NOT OUT
The wicket should either be made good by placing at least one bail on top of the wicket, or a stump must be removed from the ground with the hand or arm holding the ball.  Neither of these things happened so therefore the batsman is Not Out.
The run is made and the batting side win......the fielding Captain and his 10 players surround you the Umpire demanding an explanation....and arguing that the decision should have been Out, a Dead Ball, a No Ball, or anything other than Not Out......
Lekka Global Alliance
« Reply #21 on: July 06, 2011, 10:00:54 AM »
Nice new forum signature link Tim
langer17
« Reply #22 on: July 06, 2011, 10:01:26 AM »
If one bail had remained on then the run out would stand, but from experience, if both are blown off you must take one stump out of the ground.
Howzat
« Reply #23 on: July 06, 2011, 10:46:40 AM »
Tumo is right a dead ball can be called after the delivery is bowled.
eg. If the ball hits the batsman and the umpire thinks hes hurt badly.
In this case I think the decision would be  not out
jonwilson
« Reply #24 on: July 06, 2011, 03:38:50 PM »
We had a situation on Sunday with the batsman running a leg bye and not playing a shot. interestingly, the umpire (paid) did us a favour when he called the ball dead as soon as two of our batsman had started off for a single.  He should have declared dead ball only after the batsman had completed the run (obviously not counted as a run) or the ball had crossed the boundary.  Would have been interesting to see the fielding sides reaction if they believed they had run the batsman out.
Dead ball should not be called in the instance as described above - if the bails had fallen off before the shot was played then yes, dead ball should have been the correct call.
Batsman given not out
« Last Edit: July 06, 2011, 03:44:06 PM by jonwilson »
RossViper
  • What noise does a cow make?
    • My Excel Blog!
« Reply #25 on: July 06, 2011, 04:36:56 PM »
Ffs, is it out LBW, and both sides win.
How do people not know to pull the stump out?
« Reply #26 on: July 06, 2011, 07:39:39 PM »
 You don't need to pull the stump out, as long as the appendage holding the ball knocks a stump out of the ground.
jonpinson
« Reply #27 on: July 06, 2011, 08:14:59 PM »
Hehe. Appendage.
RossViper
    • My Excel Blog!
« Reply #28 on: July 07, 2011, 08:36:04 AM »
Thats the same thing...... to me anyway :D
