Stuart Kranzbuhler talks about Gray Nicolls e41
Pages: [1] 2 3 ... 5
Author Topic: Stuart Kranzbuhler talks about Gray Nicolls e41  (Read 18298 times)
« on: October 28, 2011, 04:56:23 AM »
Amazing bat it is! held it and loved it brilliant stick!
Re: Stuart Kranzbuhler talks about Gray Nicolls e41
« Reply #1 on: October 28, 2011, 04:57:21 AM »
Hmm not too sure about the bow/curve, but is that true?
Haven't heard that before...:S
Hads45
« Reply #2 on: October 28, 2011, 05:04:14 AM »
There ok. They do pick up light for how big they are but It doesnt feel right to me.
Richard lowy
« Reply #3 on: October 28, 2011, 08:56:32 AM »
An interesting development as a bat. The big edges are achieved by having a totally flat face and square edges, the low weight achieved through taking a large amount of wood out. The cubic mass of the bat is much less than many more conventional shapes which can affect performance. The swell is high but concentrated in a very small area. If you hit the ball regularly with perfect timing right in the centre of the drive the bat will perform well but slightly off drive because of the lack of wood it won't perform as well as other shapes. That is proven science.
The weight of a cricket bat is its volume times its average density. That is a physical fact; none of us can get around it.
Willow grades have an average density that will increase as you go down the grades. Bat makers may vary in their grading, but a Grade 1 will be pretty much the same average density as a Grade 1 used by everyone. There is no such thing as super light willow.
So, weights of bats will vary according to the volume of willow in a blade that really is what this boils down to. Seeing a big edge might give you confidence but this is misplaced if you think it will hit a ball further or more consistently.
If you like to see big edges and you hit with the consistency of a professional then this may be a bat for you. However if you hit slightly off centre the science shows you will achieve a higher performance with more wood in a more conventional shape and design.
Then there is the age old question of the square edge and its durability.....a question for another time!
Richard
« Last Edit: October 28, 2011, 09:10:47 AM by Richard lowy »
« Reply #4 on: October 28, 2011, 09:47:57 AM »
So Richard
"There is no such thing as super light willow."
How do you explain this?
http://custombats.co.uk/cbforum/index.php?topic=14120.0
And welcome to the forum
« Reply #5 on: October 28, 2011, 10:14:09 AM »
Nice to have you on board Richard - further to what you have said, what is you view on the effects of decreasing moisture content in willow?
thanks
Edward Lowy
    • Gunn & Moore Cricket
« Reply #6 on: October 28, 2011, 10:42:37 AM »
So Richard
Now make me 1,000 of those at that weight.
 :o
Kind regards
Edward
Managing Director
Unicorn Products Ltd
« Reply #7 on: October 28, 2011, 11:09:21 AM »
Still doesnt answer d7bow's question though......
thecord
« Reply #8 on: October 28, 2011, 02:32:39 PM »
 :o
Kind regards
Edward
So are you saying that this type of willow does exist just not in the quantities to mass produce?
« Reply #9 on: October 28, 2011, 02:40:22 PM »
bit of a contradiction between Richard and Edward it seems....the willow does exist but not in large volumes which is probably why its reserved for the "Pro" bats or used for the most expensive models in the retail arena (£500) ???
Canners
  • go hard or go home
« Reply #10 on: October 28, 2011, 02:52:44 PM »
Tom the players bats are LE willow remember, not player graded willow
peplow
  • Trade Count: (+77)
« Reply #11 on: October 28, 2011, 02:53:29 PM »
another contradiction being that GM dont look at any other companies "Not familiar with the bats you mention I'm afraid, we just tend to think GM" but are happy to talk down the e41 by GN.
Canners
« Reply #12 on: October 28, 2011, 02:57:07 PM »
I think the E41 looks a marvellous bat, would I get much change from 500 notes?
« Reply #13 on: October 28, 2011, 03:03:11 PM »
I tihnk they are just pointing out the obvious - that if you put extra wood into one area then normally it comes from another spot on the bat ie. the volume remains the same for any given weight...Except for the odd magic low density cleft that appears in small quantities and we rarely get to see
peplow
« Reply #14 on: October 28, 2011, 03:04:55 PM »
i dont disagree with any of the logic in it :)
