Pages: 1 [2] 3 4 ... 10
Author Topic: SA vs Aus Test Match  (Read 18607 times)
Re: SA vs Aus Test Match
« Reply #15 on: November 10, 2011, 11:54:21 AM »
SA are collapsing!!! 77-6
« Reply #16 on: November 10, 2011, 11:57:36 AM »
77-7, watsons got 5
« Reply #17 on: November 10, 2011, 12:00:33 PM »
Sounds like the Aussies had 3 weekabix each for lunch!!  ;)
« Reply #18 on: November 10, 2011, 12:04:32 PM »
81-8, like an England collapse of old!!
langer17
« Reply #19 on: November 10, 2011, 12:08:38 PM »
Good enough - probably, though I think its a risk when they also have Hussey in there that it blocks younger talent.  Personally I whint to him that he jumps before getting the push.  As for the younger talent, I wonder if they've considered Warner - as was frequently noted in the CLT20, he plays classical shots whilst hitting the ball hard and may actually be the nearest thing to Hayden that they have available.  Just a thought...
Warner also averages 59.66 from his 16 first class innings, with 3 centuries and 2 fifties. He would be a much better option than Hughes as he can actually play the short stuff.
jw17
« Reply #20 on: November 10, 2011, 12:08:49 PM »
Who else would get Eoin Morgan out of the test team and bring in Shane Watson in a heartbeat if it was possible?
langer17
« Reply #21 on: November 10, 2011, 12:09:58 PM »
IMO, Marsh should open and Khawaja should go to 3.
langer17
« Reply #22 on: November 10, 2011, 12:10:54 PM »
9/83 - Run out by Siddle
« Reply #23 on: November 10, 2011, 12:11:49 PM »
The difference is that the 'England of old' didn't contain as many top class batsmen!
When you look as the SA batting unit it is top notch! So it's a shocker when they all fall over!
The fat lady is warming up as it's 9 down now! Will be interesting to see if SA pull themselves together?
Also, unless they get another run or 2 then they could be made to follow on?
« Reply #24 on: November 10, 2011, 12:12:26 PM »
Some profile pics of bouchers halo
langer17
« Reply #25 on: November 10, 2011, 12:15:50 PM »
Australia has had 3 successful challenges and SA have had 1 unsucessful.
8/34 in the past hour of cricket.
The_Bird
« Reply #26 on: November 10, 2011, 12:17:56 PM »
The beauty of drs SA can't have any complaints, Superb accurate bowling from Watson look out Johnson is on!!
langer17
« Reply #27 on: November 10, 2011, 12:21:53 PM »
Watson got his 5 in 21 balls - Bloody Brilliant bowling.
« Last Edit: November 10, 2011, 12:28:02 PM by langer17 »
Vic Nicholas
« Reply #28 on: November 10, 2011, 12:30:32 PM »
Remarkably, Australia have a lead of 188!
SA's innings lasted less than 25 overs. Remarkable.
Australia will be hoping to bat SA completely out of the game by posting a 300+ score.
However, who knows what furrther twists this game has in store?
« Reply #29 on: November 10, 2011, 12:32:58 PM »
47 for 9 since lunch? Sheeez! That's a collapse of Biblical proportions!
Harris and Watson sounded as if they were on pretty good form!  ;)
