Poll
Preferred stance and pickup position
feet approx 2 foot apart with bat tucked behind the back leg
wide stance (3 feet?), bat tucked between
feet approx 2 foot apart with bat tucked between the feet
feet less than 2 foot apart bat tucked behind back foot
wide stance, bat tucked behind back foot
Author Topic: Preferred Stance and Pickup Position  (Read 6392 times)
« on: November 26, 2011, 01:31:05 PM »
Before we get into a series of arguments on the subject and eventually decide everyone is different, I'd like your views on the subject and any pros/cons.
The_Bird
Re: Preferred Stance and Pickup Position
« Reply #1 on: November 26, 2011, 01:37:42 PM »
I used to tap my bat behind my back foot but as I got older It felt a bit restrictive. Ever since I've tapped my bat between my legs as It feels alot comfier and negates getting pad and bat mixed up against quicker bowlers. Also only in the last 3 years I have picked up the bat prior to the bowler passing the umpire it gives me way more time against the quicks.
« Last Edit: November 26, 2011, 01:43:23 PM by The_Bird »
Maverick79
« Reply #2 on: November 26, 2011, 01:41:35 PM »
It would be interesting to see what position the stances are too - open, orthodox, closed as that is something I have experimented with in the past and have gone from orthodox to a more open stance.
I have my bat behind my back foot. Have tried it in between but it just feels odd and I feel my bat doesn't come down straight from that position.
langer17
« Reply #3 on: November 26, 2011, 01:43:34 PM »
I tap behind my back foot three times, then I get into my stance while the bolwer is around halfway through his run up.
Simmy
« Reply #4 on: November 26, 2011, 02:00:31 PM »
i tap my bat behind my back foot smashing the ground agressivly  saying to my self this is going out of the ground this is going out of the ground! woooooooooosh out lol
« Reply #5 on: November 26, 2011, 02:02:11 PM »
Very Hussey like....
100 not out
« Reply #6 on: November 26, 2011, 02:12:14 PM »
i reckon Richie Richardson used to be the best tapper
« Reply #7 on: November 26, 2011, 02:19:43 PM »
reason I was asking is for most of my cricket years it was a classical stance. However, I found  approx 2 seasons ago that putting my bat between my legs lowered by backswing and helped against the quicks. The last year or so my back has been playing up when batting, so I've widened my stance and tried to stand straighter but keep my bat touching the floor. Feel a little more balanced but my foot movement needs working on.
« Reply #8 on: November 26, 2011, 02:26:17 PM »
Mine is slightly open with feet approx shoulder width apart. Tap the bat on my boot and not the floor. Means I don't get it damp and also find myself taller, more upright and for me comfortable.
« Reply #9 on: November 26, 2011, 02:36:57 PM »
Feet shoulder width apart, tap ground behind feet once, bat held in the air, very upright with eyes level. Pretty closed.
Against left armers, open up my stance by moving front foot to the legside about 2 or 3 inches.
Johnny
« Reply #10 on: November 26, 2011, 04:25:18 PM »
....Tim bats with his eyes closed?!
Joe
« Reply #11 on: November 26, 2011, 04:54:03 PM »
I have a slightly open stance (shoulders pointing to mid on) and feet shoulder with apart. My bat will rest just outside my big toe and my backswing will come from gully. I tap a few times before the bowler runs up, and then my bat is held in the air dobbing up and down in a Trott-esque manner. I don't stand very tall, my back is quite arched.
« Reply #12 on: November 26, 2011, 05:21:06 PM »
Use the force, young paduwan.
Colesy
« Reply #13 on: November 27, 2011, 01:47:36 AM »
I have my bat between my feet and have done for the last few years but my stance is more than shoulder width and slightly open. I've been told my stance gets wider the longer my innings goes on, weird.
« Reply #14 on: November 27, 2011, 08:08:39 AM »
hello - I have an issue with your idea of a wide stance - feet 2 ft apart is a pretty wide stance - 3 feet apart is bigger than most peoples forward movement for a forward defence.
If you look in the older text books, you feet should be shoulder width apart which is typically about 18 inches (assumung you are measuring the gap from instep to instep.
Having a wider stance and then a trigger into a more natural position is a very modern technique.
It is a bit like comparing Ian Bell to Kevin Pieterson really. Actually both can work, I watched a village game where there was a more experienced player with a classic old school technique, feet close together, playing the ball late and a youngster all kevin peitersen and it was great to watch and must have been very difficult to bowl at.
Stance is a comfort thing, although i would typically encourage a narrower stance than wider, but that doesn't make me right - I just think it looks more natural.
