Author Topic: Atomic or Carbo Handles  (Read 3078 times)
kaustav
« on: December 14, 2011, 10:51:03 PM »
OK-- I have been having this discussion with a fellow forum member about the Gray Nicolls Atomic and Carbo ranges. I checked using the search function but there really aren't any discussion on this.
So my question is:
What is the difference between the Atomic and the Carbo handles? And why is Atomic priced higher than the Carbo-- what's the x-factor in the Atomic handle?
Thanks in advance folks.
In Water I trust!!
yvk3103
Re: Atomic or Carbo Handles
« Reply #1 on: December 14, 2011, 10:55:16 PM »
Never been a  fan of the GN Atomic and Carbo versions. Think it is more to do with the willow grading than the "X-factor" in the handle.
Maybe someone who has taken the handles apart might know the difference.
kaustav
« Reply #2 on: December 14, 2011, 10:57:23 PM »
They say stiffer handles give you more value for shots  ;)
I have both and apart from the Atomic and Carbo tags it is really difficult to differentiate the feel.
In Water I trust!!
norbs
« Reply #3 on: December 14, 2011, 11:25:41 PM »
True but they'll be illegal handles even for Type C bats!!
« Reply #4 on: December 15, 2011, 01:30:18 AM »
As long as it is less than 10% of the handle it is fine!
norbs
« Reply #5 on: December 15, 2011, 07:58:20 AM »
20% for Type C
kaustav
« Reply #6 on: December 15, 2011, 08:01:48 AM »
So would the GN Fusion be a Type C?
In Water I trust!!
« Reply #7 on: December 15, 2011, 08:05:35 AM »
I believe the Fusions were made prior to the introduction of the handle materials rule, and if they were made today, they wouldn't fit any of the types.
norbs
« Reply #8 on: December 15, 2011, 08:06:05 AM »
If you mean the old GN carbo handle... then if it was made after the law changes if would be illegal
kaustav
« Reply #9 on: December 15, 2011, 08:08:06 AM »
Thanks guys  ;D
In Water I trust!!
thebigginge
« Reply #10 on: December 15, 2011, 08:16:34 AM »
Atomic Handle
8 - 12 piece laminated cane handle that has springs made from carbon fibre rather then cork or rubber. Giving a stiffer handle so less energy is lost when striking a ball. Fitted with a large transparent handle cap on the end to rduce acoustic difference. Basically it was another twist on the original steel spring handle.
Carbo Handle
8 - 12 piece laminated cane handle with cork springs that has carbo fibre re-enforcement attached to the exterior of the handle from the top of the splice for about 5 inches, to offer protection to the handle from ball strike as the base of the handle is a natural stress point.  Fited with a black handle cap.
CARBON Handle
Only ever fitted within the fusion range, a 100% carbon fibre handle that weighed less than  1/3 of the weight of a cane handle. The theory was that you can keep the weight within the blade giving you a bigger profile.
Hope this helps
Alex
kaustav
« Reply #11 on: December 15, 2011, 08:18:32 AM »
Atomic Handle
Carbo Handle
CARBON Handle
Hope this helps
Alex
Definitely helps Alex. Thanks boss.
In Water I trust!!
« Reply #12 on: December 15, 2011, 08:22:22 AM »
Canners
  • go hard or go home
« Reply #13 on: December 15, 2011, 08:43:13 AM »
I had a rapier carbon, the pick up was horrible because of the light handle
