Author Topic: removing scuff sheet  (Read 1358 times)
cricketbadger
« on: December 27, 2011, 06:05:07 PM »
any ideas or help at how to best do this? its a bat i was given during last season.
a Hunts County clipper i think not sure of its quality or performance because not had much chance to use it
im not too keen on the Hunts stickers (they are the older ones ,i.e 5 or so years old) and want to completely renovate it to the best of my ability and maybe some new stickers.
firstly i need to remove the scuff sheet,from what i can tell the sheets been on since new. dont want to remove it and be left with the wood being all sticky and messy.
is there a method or anything i can do to stop this and remove it cleanly,or if not how can i clean it up once its removed?
any help would be appreciated
cheers
TCA Coach
Joe
Re: removing scuff sheet
« Reply #1 on: December 27, 2011, 06:20:11 PM »
Make sure you remove it sideways from one edge to the other and not top to bottom or it'll take off a lot of wood. After that if there is no glue on there then a quick sand will do it. If there is glue then scrape it off then sand.
peplow
  • Trade Count: (+77)
« Reply #2 on: December 27, 2011, 06:20:27 PM »
hairdryer always helps loosen glue, pull slowly across the bat, and it should minimise the problems!
cricketbadger
« Reply #3 on: December 27, 2011, 11:30:34 PM »
cheers fellas
all stickers and scuff sheet have been successfully been removed with minimal glue left
TCA Coach
