Author Topic: How to stop pads squeaking!!??  (Read 6651 times)
Liam-SCCC
« on: January 13, 2012, 01:06:33 PM »
So, nightmare, my new Uzi pads squeak against my shoes!
What can I do to combat this?
Thanks
Top Score: 102*
Best Bowling: 7/29
langer17
Re: How to stop pads squeaking!!??
« Reply #1 on: January 13, 2012, 01:09:24 PM »
Wear longer pants so that the pants create a barrier between the two.
« Reply #2 on: January 13, 2012, 01:10:50 PM »
either a little bit of electrical tape around the bottom of the pad or some vaserline on the shoe or pad...
Liam-SCCC
« Reply #3 on: January 13, 2012, 01:14:21 PM »
What about that cloth tape you can get? Would that be any good?
Top Score: 102*
Best Bowling: 7/29
Liam-SCCC
« Reply #4 on: January 13, 2012, 01:21:58 PM »
Thanks buzz, just mocked up some electrical tape on there and it works good. That will have to be a quick fix, then I'll get some of that cotton tape like GN use for bat repairs
Top Score: 102*
Best Bowling: 7/29
« Reply #5 on: January 13, 2012, 01:23:30 PM »
the cloth tape will work ok, but will leave a grey and sticky mark on your shoes and pads - i used some of this on a old set of pads I used to use as I had worn a hole in the bottom of them.
To be honest it will stop once the pads have been worn a few times in the indoor nets - I would wait a while before you start defacing your new pads :)
yvk3103
« Reply #6 on: January 13, 2012, 01:33:01 PM »
cloth tape or pull the shoe flap out (like Dravid does)
« Reply #7 on: January 13, 2012, 01:49:06 PM »
If you take the vaseline method, just ensure you do it outside of the changing rooms! Walking into a changing room with a room full of bloke and a jar of vaseline in your hands is likely to make a few of your teamates nervous!  :o
« Reply #8 on: January 13, 2012, 01:52:27 PM »
Hope my new pads squeak when they arrive....fingers crossed
Liam-SCCC
« Reply #9 on: January 13, 2012, 01:53:50 PM »
Is the Vaseline a one off thing? Or would I have to do it before every match?
Buzz, would the cloth tape only leave marks when you take it off?
And where can I get cloth tape off?
Top Score: 102*
Best Bowling: 7/29
Bulldog Cricket
  • Trade Count: (+31)
    • Bulldog Cricket
« Reply #11 on: January 13, 2012, 02:00:26 PM »
Thanks
Use them Liam !! Ie wear them in. The more you use them the more supple they will get. I guess if at the end of the season they are still squeaking then you have not scored enough runs !!
Liam-SCCC
« Reply #12 on: January 13, 2012, 02:03:53 PM »
I just don't want them being all squeaky for my first net on Monday night.
I mind try Vaseline then if it's a one off thing, was think anti scuff could be a could idea.
The general consensus is to loosen them up and they will stop squeaking then
Top Score: 102*
Best Bowling: 7/29
Canners
  • go hard or go home
« Reply #13 on: January 13, 2012, 02:08:47 PM »
Bulldog is completely right, you just have to wear them in
Liam-SCCC
« Reply #14 on: January 13, 2012, 02:11:27 PM »
Will having tape on the I step affect this wearing in?
Top Score: 102*
Best Bowling: 7/29
