Pages: [1] 2 3 ... 5
Author Topic: Tonights Net- New videos  (Read 14523 times)
Bruce
« on: January 19, 2012, 04:59:35 PM »
Good arvo all.
So, I have not stopped playing since the end of the season in September, be it Nets, Coaching or Indoor games.
I'm feeling in good nick, driving the ball well and off my legs (my strongest area) is coming on well.
I'm looking to ramp it up now and and would appriciate any help/ pointers of where to go next.
Video:
Video 2:
Sir Philip BUZZington has viewed the videos and given me some pointers on what to work on with my grip and being stiller at the crease.
I have been working on this, and will film tonight to show where I'm at the moment.
I cant for the life of me play the cut, never been able to. Any ideas?
Thinking about going on the short stuff tonight.
The pitches in Dorset are mostly low and slow but on Sundays we do get some decent bowlers.
All the Breast
Dave
« Last Edit: January 27, 2012, 01:24:17 PM by Bruce »
cricketbadger
Re: Tonights Net.
« Reply #1 on: January 19, 2012, 05:05:38 PM »
first shot must have been good managed to hit 2 balls  ;)
TCA Coach
Bruce
Re: Tonights Net.
« Reply #2 on: January 19, 2012, 05:06:44 PM »
Well I don't like to bragg  8)
Howzat
Re: Tonights Net.
« Reply #3 on: January 19, 2012, 05:18:48 PM »
Similar issue to me, your always moving after you've hit the ball which indicates your not balanced. How to fix this... im not quite sure!
Re: Tonights Net.
« Reply #4 on: January 19, 2012, 05:21:13 PM »
All the Breast
Dave
I'm a leg man...
Bruce
Re: Tonights Net.
« Reply #5 on: January 19, 2012, 05:24:05 PM »
Yep, Trying to cut it out.
The way I'm trying to oust it is by running a 2 every time I come off balance. Make it hurt me!  >:(
 #That'llLearnHim
PedalsMcgrew
Re: Tonights Net.
« Reply #6 on: January 19, 2012, 05:30:08 PM »
Yup, I agree with Leo, your playing every shot 'on the move'. Other than that there doesn't seem to be much wrong! Looks like a pretty solid technique to my untrained eye. I'm sure Buzz can point you in the right direction re: drills to eliminate this. If I were you I would book an hour of one to one coaching. It's always money well spent....
Lisa: How's my Rabbit?
Bruce
Re: Tonights Net.
« Reply #7 on: January 19, 2012, 05:33:53 PM »
Thanks PmcG.
The Other thing I want to get out the very wide backswing...  :(
But all in due course.
PedalsMcgrew
Re: Tonights Net.
« Reply #8 on: January 19, 2012, 05:38:53 PM »
If you mean your backswing when you pick up the bat, I had the same problem, I always brought my bat down from about 2nd slip and therefore played across everything but when I last got some coaching he told me to make sure the back of my right hand was touching my backleg as I picked the bat up. It really helped. Dunno if that's what you meant though  :)
roco
Re: Tonights Net.
« Reply #9 on: January 19, 2012, 05:43:27 PM »
May be me but you seem to be arching your back a lot so head is outside the body so may be affecting the balance
Re: Tonights Net.
« Reply #10 on: January 19, 2012, 06:35:45 PM »
if people want to stop playing shots on the move you can do this on your own.
stand in your normal stance and put a semi circle of balls, can be cricket or tennis, effectivy from ten to to ten past if you can imagine that the lean forward and play a drive at each ball in succession holding your position after each hit the repeat and repeat and repeat...
I hope that makes sense.
as for playing the cut, read bob woolmers book on that, but your position, especially head and back foot is important, as is really throwing your hands through the shot.
early season it can get you into trouble.
Joe
Re: Tonights Net.
« Reply #11 on: January 19, 2012, 08:20:16 PM »
Having a backswing from 2nd Slip/Gully is a good thing. It allow you to play off your legs/pull easily, and, if done properly, when driving you will straighten your backswing before playing the shots. All the greats do this.
Simmy
Re: Tonights Net.
« Reply #12 on: January 19, 2012, 08:40:50 PM »
i tend to find after following buzz's advice about my back swing that i am more in line with shot when keeping my bat straight and i find i generate alot more power when i do this
Re: Tonights Net.
« Reply #13 on: January 19, 2012, 08:42:27 PM »
sorry no.
this is not true, or helpful.
Ryan
  • Trade Count: (+17)
Re: Tonights Net.
« Reply #14 on: January 19, 2012, 08:45:35 PM »
As said before you fall away a hell of a lot but only seem to do it when playing leg side. Kind of started to annoy me if I'm being honest.
You seem strong through the off side and very balanced. Just try and keep your head over the ball. Currently your head is over the offside of the ball which is putting you off balance.
